-   Rules/Strategy (http://www.chiefdelphi.com/forums/forumdisplay.php?f=6)
-   -   Guess the High Goal Shooter Accuracy (http://www.chiefdelphi.com/forums/showthread.php?t=153590)
rich2202 13-01-2017 16:09
No doubt you can design a shooter that unloads 3-5 Fuels a second. The question is: How accurate do you think a team can get it.
Assuming that you miss 1/3 of the Fuel, the comparison of low vs high makes high shooting less compelling.
TJP123 13-01-2017 16:31
Re: Guess the High Goal Shooter Accuracy
If you miss 1/3 of the high goals, and none of the low goals, the high goal is still worth twice as much.
Assuming the same rate of fire, and 100% low goal accuracy, you need to shoot with 34% accuracy in the high goal to be worth it.
Chris is me 13-01-2017 16:34
But comparing low vs any other task in the game makes low shooting seem pretty worthless. I mean, collecting and carrying balls itself has worth, so if you need somewhere to put them, it's better than nothing, but that's about it (well, other than... nevermind).
Assuming that 5 balls per second processing rate is a hard limit, the low goal is capped at 75 points in the teleoperated period, which can be accomplished by scoring as few as two gears.
Shavan M. 13-01-2017 16:51
In my personal opinion if you shoot, all you need to go for is the high goal. This makes more teams likely to pick you for alliance selections (assuming you are not a captain), because the way I see it is the captain of the alliance will be focusing on climbing, and gears since it has a 100 point value in eliminations if you turn all rotors, and the first pick will either be a high goal bot that does not miss often or an efficient gear robot. The second pick will either be a defensive bot or a high goal shooter.
seg9585 13-01-2017 23:54
100%
Balls that miss the high goal roll back down into the robot's hopper, are shot again, until all balls are in.
