-   Electrical (http://www.chiefdelphi.com/forums/forumdisplay.php?f=53)
-   -   Best source for a potentiometer? (http://www.chiefdelphi.com/forums/showthread.php?t=42944)
vivek16 28-11-2007 19:02
Re: Best source for a potentiometer?
I have heard to avoid radio shack. Digikey is used often. and they have a cool selection process.
RyanN 28-11-2007 19:09
I'd also say to avoid Radio Shack. I purchased a potentiometer there for our robot last yearand I could only use about half of the rotation because it would give the same value close to the extremes of rotation.
Alan Anderson 28-11-2007 20:49
You might have accidentally purchased a "log taper" or "audio taper" potentiometer. For position sensing, a "linear taper" pot is preferred.
Pavan Dave 28-11-2007 22:02
Two solutions. Either a 10 turn pot if you want or you can couple two continuous pots to cover all 0-259 degrees. I'll get part numbers for ya tomorrow.
Gdeaver 28-11-2007 22:23
The Ametes absolute position sensor is ideal for arm position. It would have to be mounted on the joint. If the arm joint design does not permit mounting on the joint, It could still be used with some additional programming.
RyanN 28-11-2007 22:24
I ended up ordering this potentiometer:
http://webtronics.stores.yahoo.net/73jb50k.html
Hopefully it will arrive soon and work well.
