Re: Dashboard Port Decoder
I just obtained an old basic stamp that can be programmed using basic stamp. Right now it can obtain data from an old FRC, but just simple stuff. I am expanding it to work with the real FRC.
If you have that C code, that would still be helpful I think. Thank you, Jacob Komar |
1 Attachment(s)
After a day's work on this, this is how far I got.
The Basic Stamp can see the dashboard port, because it doesn't get hung on the 255,255. My problem now is capturing the correct packets. Do I need to name the input varibles the same as they are in the specification sheet? Even if they do, the one that I care about, Switches_A, doesn't pass bit0, which is just p1_trig. Does anyone see any syntax errors? Just remove the .txt at the end of the file name to get the bs2. Jacob Komar |
OK!
I got the stamp to read values from the OI packet, so when I press the trigger, I can make the logic value of a pin high; when I let go, it will go to low. As soon as I move the jumper over to RC next to the dashboard port, and write my code to check the ctrl_a, b and c to suck a certain byte (PWM 1, for instance,) it isn't reading properly. For some bytes, only the lows will work, but when i try to switch it to a high, i get a 2.7 voltage, and other bytes are just 0 all the time. Any suggestions? Jacob Komar |
post the most recent code. I might have an idea about why it might not work You seem to be on a good track with the BASIC stamp, so i'm not going to bother with the C code. |
1 Attachment(s)
Here is the latest code. Right now its written to capture the first Packet of the RC code and the 3rd byte, which is PWM 1. When PWM 1 is 0, the output 7 is 0 V, but when it gets above 150 (or whatever it is), it jumps all around.
Remember to remove the .txt Thanks, Jacob Komar |
Oh, I'm sorry about that. I had adjusted the code for the OI, and I readjusted it for the RC so I could post it. I must have uncommented too many things. The version that I used yesterday for the RC decoder compiled properly. I tried multiple ways of using if statements to check those control bits, so I had ifs all over the place. I must have uncommented it by accident.
Jacob Komar |
3 Attachment(s)
I GOT IT!!!!!!!!!
I don't know how I did it, but I got it. I updated the code, (not much of a difference,) but now it works. I also attached the code I downloaded to the FRC (I did it in easyC so that I knew it wasn't my crappy C coding that was the problem :o ). YAYAYAYAYAYAYAY!!!!!!! My xilinx board is currently on the truck to my house, so later on I can work on the xilinx code for decoding the stuff that comes out of my stamp. I'll keep you guys updated!!! Jacob Komar |
I lied. Only PWM 1 works, and only a little bit at that. Sometimes, the light stays solid at 5 Volts, but sometimes it blinks (between 0 and 30 V.) Its very confusing. Any other byte from the packet produces no output. Any assistence is greatly appreciated.
Jacob Komar |
As i understand things, you have a Basic stamp connected to the OI. The Basic stamp is also connected to an LED. Is this correct? How does a ligh blink at 30v? do you mean 30hz? What is it that you wrote in easy C? I thought you were using a Basic Stamp? I'm confused. |
| All times are GMT -5. The time now is 05:18. |
