Re: Empty Field Picture
I found a picture on Google.I hope this helps :D !
The only thing I am worried about is if the pixels will stretch. However, you can always fix that in Adobe Premier Pro, if you have it? |
Here is a google docs link to the .bmp download: https://docs.google.com/leaf?id=0B2j...mNjg4&hl=en_US Quote:
sorry. as i said, its bland and im not exactly sure how much i can mess with it since its a converted file and 1 part and they used weird methods. Ill look at it later. what view are you wanting because i thought that's how you wanted it. do you want a higher view than that? |
Edit: Also, With a the appropriate render of just the gray CAD you could just use photoshop or gimp or similar to add the colors. It could be tricky to get the anti-aliasing just right. |
I took this one at the Lone Star Regional after we had set up the tubes on the outside of the field.
Its the best live view shot of the field that I have. ![]() |
This is ChiefDelphi after all, what else would you expect :D |
I have very little experience with photoshop. Ah well, he finally got the picture he needed. Its actually kind of surpising there wasnt a picture of a blank field that could be easily attained |
Its so much easier to just go into the ole camera phone and pull off a photo :) ~Stash~ -Non-engineering mentor- |
| All times are GMT -5. The time now is 02:30. |
