Go to Post Great people like you both [Scott and Libby Ritchie] make the FIRST community even better! - tiffany34990 [more]
Unread 31-10-2002, 16:05
Matt Reiland's Avatar
'The' drive behind the drive
This is from the archives I assume it to be close
close enough for govt work...
Posted by control guy at 1/29/2001 10:29 AM EST
Student on team #250 from HVCC.
In Reply to: Re: PBASIC Loop Speed?
Posted by Lloyd Burns on 1/28/2001 4:38 AM EST:
The program loops are roughly 1/40 sec. Although, the time between loops can vary if you lose signal momentarily. Also, depending on your code, a program loop may take longer some times around than other times. Such as if you had many strings of if statements and you're having the program go here, then here, then here, etc., etc. Hope this helps.
PBASIC Syntax Question Raven_Writer Programming 4 20-08-2003 08:07
Question Obtaining Pbasic 2.5 PyroPhin Programming 3 18-01-2003 01:26
pbasic question Mike375 Programming 14 15-01-2003 06:54
pbasic question archiver 2001 5 23-06-2002 23:50
Another PBASIC Question Ian W. Programming 4 31-01-2002 21:36
