Go to Post ...and that is exactly why Dave is the coolest nerd I know. - Rich Kressly [more]
Unread 01-11-2002, 10:23
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
More than 2 aux switches in 1 port
Is there a way to do more than 2 aux switches in 1 port? This is my first year doing something other than the construction of the bot, so sorry if I ask stupid questions.
I think I could do it by wiring a switch into the pins normally used by the joystick buttons, but if there is a better way I would like to know.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 01-11-2002, 13:59
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Each port can have a maximum of four switches and four axes. The switches can be wired into trig, top, aux1, and aux2 and are normally used for limit switches, optical sensors, or the pressure sensors. The axes are wired into X, Y, Wheel, and Aux. They are used for pots or gyros.
Unread 01-11-2002, 14:44
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
http://www.innovationfirst.com/FIRST...sersManual.pdf
Each port, as said above, has 4 analog inputs (0-5V) and 4 digital inputs (on/off).
The pinouts for the ports start on page 14 in the link above. The function isn't set in stone, because it can be used for anything really. You just gotta program it different then.
If you run out of switches you can always start using analog inputs.... You'll just have two settings when you program it: 0 or 255.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Competition port cable Ken Leung Electrical 2 17-09-2003 08:12
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
Need help with custom switches archiver 2001 3 24-06-2002 00:35
