Go to Post On the contrary, you've had several helpful responses. You might be confusing "helpful" with "do my homework for me." - Rick TYler [more]
Unread 06-11-2002, 21:30
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Given that you hooked your HC08 up to the tether port, I assume you must have a pinout. If so, would you mind sharing that? If I knew which pin the +12V was on, I could merely disconnect that wire in the serial port and wouldn't have anything to worry about.
Also, would you mind sharing the HC08 setup, as this could be a fun project while we wait for Jan 4, and at $3 it would definately be one of the cheaper ones.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
how do you power on the robot control great_one411 Electrical 6 04-02-2003 00:46
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
robot control emulator for default or other program CharlieWilken Programming 26 24-02-2002 02:36
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
