Go to Post But no matter how you place, the thing to watch for is the character change in the team members. The trophies are only important for a few hours. The character that is built will last a lifetime. - BrothersKeepers [more]
Unread 09-11-2002, 19:34
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Ken hit most of the key points, but I think some simple equations would be useful.
Electrically: Power = Voltage * Current
Mechanically: Power = Torque * Rotational Velocity
Thus:
Voltage * Current = Torque * Rotational Velocity
This is only true if motors are 100% efficient at turning electrical into mechanical energy. In reality, motors are not. DC motors are extremely inefficient when they are stalled (NO mechanical energy is produced but TONS of current is being drawn), but pretty good when the load on the motor is less. That is why the motors heat up so much if the robot is in a pushing match.
Really:
Voltage * Current = Heat + Torque * Rotational Velocity
Heat = Voltage * Current - Torque * Rotational Velocity
Efficiency = (Torque * Rotational Velocity) / (Voltage * Current)
I think Ken's link is likely to provide graphs of most of these.
Now, how can we not waste this energy to heat? The answer is a transmission (continuously variable is nice, eh team 190?). If we are going to be pushing against another robot and likely to be close to stall torque, we change our gear ratio on the fly such that we provide a lot more torque and a lot less rotational velocity. This way we can push what we want to push at the expense of speed.
- Patrick
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
4WD with 4 motors archiver 2001 8 23-06-2002 22:58
Multi Motor Drivettrains Ryan Curry Technical Discussion 9 08-04-2002 08:18
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
