Go to Post We are not the families of competiting robot teams, but we are a family of Gracious and Professionalism, because we know it better than anyone in the world. - wsansewjs [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 18-11-2002, 22:34
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Somewhat yes, somewhat no.
Basically, it runs the program loop exactly as if it was in non-autonomous mode. The only difference is that all the variables from the OI (p1_x, p1_y, p1_sw_trig, etc) are set to 127 or 0, depending on whether it is an analog or digital input, respectively. The inputs on the RC (rc_sw1, sensor1, etc) still contain the correct values.
One of the bits of the competition mode byte is also set but I can't remember which. It's documented in the default code if you need to know.
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
Autonomous code tutorial miketwalker Programming 2 23-02-2003 12:28
Overcomplicated Autonomous Code EbonySeraphim Programming 33 20-02-2003 21:53
Autonomous code PBoss Programming 7 14-01-2003 15:29
