Go to Post Now Dave, before you get all snarly about these- remember, I still have the button maker... - MissInformation [more]
Unread 30-11-2002, 13:04
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Technically you should use NOT instead of ~ for things like this. Also, you should use AND instead of &. & will calculate the bitwise "and" of your two expressions, meaning it will apply the "and" to each individual set of bits. If it so happens that both p1_y > 127 as well as p2_y > 127 evaluate to exactly 1, it will work. Otherwise it may not. ~ Will compute the bitwise NOT of your expression. Assuming the inner part evaluates to 1, ~ will make it 1111111111111110 (65534).
If you ever wonder what an expression will evaluate to, try popping it in RoboEmu and doing a debug. For example, using:
myVar= ~1
debug? myVar
will give you:
myVar=254
-and-
myVar=0-1
debug? myVar
will give you:
myVar=255
I'll delete this in a couple of hours. hixofthehood Chit-Chat 9 04-02-2003 23:26
couple of questions... archiver 2001 5 23-06-2002 22:48
A couple of problems I observed at the MAR archiver 2000 3 23-06-2002 22:27
Couple other thank yous Jason Haaga Thanks and/or Congrats 0 29-04-2002 03:29
A Couple Questions about Chairman's Award ben_whly Chairman's Award 4 26-01-2002 18:24
