Go to Post I had a life before FIRST - I just can't remember what it was. - Tom Ore [more]
Unread 09-12-2001, 00:14
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Lightbulb FP Transmission Posted ....
Well the FP Transmission is finally completed and posted in the mechanical library of the FIRST CAD Library. This one was tough. Injection molded stuff is a pain to draw and be warned that I had to make a few judgement calls and assumptions. The model is close but if you are going to make a part to capture the housing then I would invest a little time in comparing the model to your actual part. I tried to pay close attention to the end of the model where the output shaft is. The 3 screw pattern and the final gear shaft are pretty close to the FP transmission I have.
BTW This part is metric (mm)
FIRST CAD Library
Ed Sparks
MECH TECH FRC-3959
White Paper Discuss: Locking the Bosch 3360 Drill in low gear CD47-Bot Extra Discussion 4 05-08-2003 02:10
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
Replacement Bosch drill motor assembly james700 Motors 3 31-01-2003 21:08
Should FIRST include Bosch Drill Motors in Next Years Kit of Parts mtaman02 Motors 9 05-07-2002 16:32
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
