Go to Post I'm still trying to find a way to get FIRST to dump the Chicken Dance song. :p - Koko Ed [more]
View Poll Results: Is shifting necessary?
Absolutely: you must shift to be competitive. 25 24.27%
Shifting would help a great deal in the game. 54 52.43%
Single speed works just fine. 19 18.45%
Building a shifting tranny is NUTS. 5 4.85%
Voters: 103. You may not vote on this poll
Unread 04-12-2002, 20:39
FatNick's Avatar
FatNick FatNick is offline
#0180 (SPAM)
FatNick is an unknown quantity at this point
Send a message via AIM to FatNick
jonathan lall.
IN your case yes it is a little simpler but think all that power you draw with fluffy we only had 2 (4 in all) motors on each side and we could barley last one match only those 4. on the other head yes ots simple but in order to get maxium speed and torque you need to either shift or have CVT. Cvt is a litle bit to complicated and not as reliable as shifting. We only had to gears and what we can do with those blows my mind. I dont mean to bragg but we were playing with fluffy.(last years bot totaly unchanged except for a few bolts) A few of our enginners wanted to see what she could do well, we had her climing a 60 degree angle like it was cake it felt like a stunt from the dukes of hazzard. But any ways, in a higher gear becuse we have so much traction we would have just stalled the motors and popped the brakerr or if we lost traction we would have just spun our treds at a high rpm and make no progress. Well becuase of a lower gear and shift on the fly all we had to do was flip a switch. this gear shifting gives us an advantage more power and lower rpms allowing us to get maxium power and never really loose traction and using the power curve to the best of it ability.
Fat Nick
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
for fun and boredom mjt902 Technical Discussion 11 26-04-2003 14:11
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
drill motor transmissions nwagers Motors 16 29-01-2002 10:54
