Go to Post My driving skills are only slightly better than my dancing skills... - RoboMom [more]
View Poll Results: Is shifting necessary?
Absolutely: you must shift to be competitive. 25 24.27%
Shifting would help a great deal in the game. 54 52.43%
Single speed works just fine. 19 18.45%
Building a shifting tranny is NUTS. 5 4.85%
Voters: 103. You may not vote on this poll
Unread 05-12-2002, 17:28
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
I don't know about all of you, but when i look at the design's for gearboxes and transmissions in the white pages and what i seen at nats last year, i seen a WHOLE lot of metal! That has to be a huge amount of weight to slap on a drivetrain! To maybe loose a little acceleration you could use a simple geared down (or up) shaft with a cupling and sprocket. Even if you wanted added torque, simply meshing in another motor wouldn't add up to the weight of a transmission. Keep in mind that a few ounces off a drive system is another few ounces available towards a mechanism.
Now i take this position on this subject because of last years game. We have a very muscular drive system on EL TORO, a VERY VERY muscular one that took up every ounce of weight available. Now, dopn't get me wrong the extra power was outstanding and we could push anything we tried, but as a result of the robustness we had no room left for a claw to get the goal. The reason for the power in the drive train was to push two goals. Now we over estimated the resistance in moving two goals at a time so by the time we finished the bot and tested it on a goal we realized how we didn't need even close to the amount of power we established.
POINT-- I would use the extra weight for a more practical use in the game.
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
for fun and boredom mjt902 Technical Discussion 11 26-04-2003 14:11
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
drill motor transmissions nwagers Motors 16 29-01-2002 10:54
