Go to Post Certainly more interesting to watch than driving around in circles on a flat field. Sorry, 2008. - synth3tk [more]
View Poll Results: Is shifting necessary?
Absolutely: you must shift to be competitive. 25 24.27%
Shifting would help a great deal in the game. 54 52.43%
Single speed works just fine. 19 18.45%
Building a shifting tranny is NUTS. 5 4.85%
Voters: 103. You may not vote on this poll
  #31   Spotlight this post!
Unread 06-12-2002, 11:41
Neal Probert's Avatar
Neal Probert Neal Probert is offline
#1015 (Pi High Samurai)
Neal Probert is on a distinguished road
Send a message via ICQ to Neal Probert Send a message via AIM to Neal Probert Send a message via Yahoo to Neal Probert
Shiftless in Ann Arbor
If you have to stop to shift gears, it's not worth it. You only have a couple minutes in the contest and wasting time just shifting gears is not a good idea.
We tried it, with the shifter on the drill motors, last year on #830. With the servos linked to the clutch on the drill motors, it never really worked right.
We had to lock the clutch to prevent slipping and we eventually locked the drill into low speed. We could push around a bit and still get across the field reasonably fast.
This year, on #1015, we have tentative plans to go with a dual motor gearbox.
Ypsilanti-Ann Arbor Area Robotics Club
YAAARC! The sound you make as your robot rolls off the workbench...
http://www.yaaarc.org/
Software Engineer (20+ years experience)
ProbeStar Technical Systems, LLC.
http://www.probestar.com/
  #32   Spotlight this post!
Unread 06-12-2002, 15:52
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Shiftless in Ann Arbor
It depends on your mission whether or not taking time to shift is a waste of time. It also depends on the length of time it takes to make the shift and how reliable your system is.
There's your problem right there, servos. A small pnuematic cylinder works much better for shifting if it is properly linked to the tranny. The pnuematics are also much faster and if all you are doing is shifting, you probably don't need the compressor either.
Locking the drill motor clutch should be standard procedure. If your low speed was still reasonably fast it was geared too high to start with.
Hope you're working on it already, not the real one, a prototype of course!
Christopher H Husmann, PE
"Who is John Galt?"
  #33   Spotlight this post!
Unread 06-12-2002, 19:12
FatNick's Avatar
FatNick FatNick is offline
#0180 (SPAM)
FatNick is an unknown quantity at this point
Send a message via AIM to FatNick
In spam 180s case we used a shift on the fly design and numatics to shif. they worked out well together. and the sensors desined to work with that reflective tape they work great in the shift on the fly area the drive train.
Fat Nick
  #34   Spotlight this post!
Unread 06-12-2002, 19:18
FatNick's Avatar
#0180 (SPAM)
Re: Re: Shiftless in Ann Arbor
IN spams case that compressor was the most important thing on our bot, yes we also had a pnuematic goal graber but we shifted back and forth between gears at least 10 times in one match. we even broke our toggle switch to sift one but thanks to our driver who has long finger nails (he plays guitar) we were still able to shift.
Fat Nick
  #35   Spotlight this post!
Unread 06-12-2002, 19:56
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Its worth it if you know how
i think that it is bsolutely necessary to shift during game play. our robot had 4 wheel drive, witht he technocats transmission desigm, and our matching, patented designed for the chiapuah motors. its shift on the fly, and extremely reliable. you cant do much without shifting.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
  #36   Spotlight this post!
Unread 08-12-2002, 11:24
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
Originally posted by sanddrag
Those bosch gearboxes are pretty fragile from our experiences.
Most of the fast and powerful teams shift these days. It is a necessaty to have a machine that has more than one configuration. The way that the games have a qualifying session and an elimination run, require you to have different strategys to be competitive. Most of the teams who were in the final rounds of the Nationals were bot's with split personality transmissons. To us this extra time and effort seems worth it.
We have been using the Bosch trans for some time now. This year is the first year we decided to shift. We however, decided to shift using servos utilizing the stock housing and shift ring--if anybody watched Team 27 in the pits, they usually saw us constantly going through that silly system! We like the compact size of the planetary system, although they do have more friction than a spur gear style trans.
To avoid the struggle of 2002, 2003 guaruntees we are using a Drag race inspired Air Shifter, also promises a new Aluminum trans housing. A new "Shift Ring" made of steel or brass. A one piece Housing for both the planetary sections and out put. If anyone has seen our trans assembly, then they have seen how we eliminate the clutch. I have all this drawn in AutoCad 14 as a 3D file. If anyone has any questions on how this looks or works I be happy to share some data.
Racing is an incurable addiction!!
  #37   Spotlight this post!
Unread 08-12-2002, 11:59
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Its worth it if you know how
Did you really patent it? Rock on T3.
Let me know when the FIRST royalties start flowing in.
Of course you'll have to pay 45 for using part of their design...
  #38   Spotlight this post!
Unread 08-12-2002, 23:37
Antonio Antonio is offline
Antonio is an unknown quantity at this point
I've heard from some of you that change gears refer to the Bosch gearbox, do guys mind telling me what that is, since my team is interested in switching gears for this years competition Thanks!
  #39   Spotlight this post!
Unread 09-12-2002, 00:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The bosh gearbox is also referred to as the drill motor gearbox. it is pictured below. It has a shifting mechanism that uses a shift lever and two sets of internal planetary gears. High speed gives 1000 rpm and a stall torque of 10Nm and low speed gives 300 rpm and a stall torque of 29 Nm.
www.team696.org/motorspecs.html
Name:	drill gearbox.jpg
  #40   Spotlight this post!
Unread 09-12-2002, 07:24
For Rookie Teams...
We should remind everyone of the locking pawl in the drill motor transmission. There is a white paper on this board about how to remove that little tooth. With the locking pawl in place you are almost assured to breakout the transmission case during competition.
  #41   Spotlight this post!
Unread 09-12-2002, 13:50
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
You know how hand drills have a little switch that makes it spin slower but more torque? That's what teams use in the drill motors to shift gears. What you couldn't see in the picture of the drill transmission, is a silver strip of metal that you can move back and forth to select either high gear or low gear. Teams usually use a servo motor for each drill transmission to move that metal strip to switch gears. I know some teams use pneumatics to do that as well.
There are planetary gears inside the drill transmission. The metal strip engage one of the ring gears that slide from one stage of the planetary gears to another. In High gear, that ring gear is in a position where it lock one stage of planetary gears together so that it act like as if that stage doesn't exist. When you switch to lower gear, the ring gear slide out and unlock that stage, adding further reduction to the transmission causing the output shaft to spin with a slower rpm, but higher torque.
Of course, this isn't the only way to do this. There were different transmissions I've seen in the past years, and the technokat's servo transmission is only one of them. There are other ways like
having another set of wheels on your robot with a different gear ratio, and you lower those wheels when you want a different speed/torque combination. I've seen this on 131's 2000 bot, and 258's 2002 bot. Changing wheels size is also a mean of switching gear ratio too.
There are also ones where there are two set of gears on the same shaft, and only one set is engaged at a time, and you use pneumatics to engage the other set of gears for a different ratio. I've seen this on 67's 2001 bot, and 45, 60 and 254's 2002 bot last year.
Then there were other teams who lower another set of drive train with a lower gear ratio, like 111 and 810 last year I believe.
But most teams use the servos to switch gears on the drill transmissions because its fairly easy to do. You just got to figure out a good servo mount on top of the transmissions, and make sure the linkage between the sergo output arm and the metal strip is good enough.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
  #42   Spotlight this post!
Unread 10-12-2002, 22:41
so, if we used the Bosch gearbox......would that, say, lower our speed or reduce our torque compared to having a gearbox that fully switched gears using pneumatics and stuff like that?? because I'm not sure how powerful these bosch motors would be compared to different gear ratios
  #43   Spotlight this post!
Unread 10-12-2002, 22:53
also, how would we design the bosch motor to shift gears, if we were to use it as a shifting motor?? pneumatics?
  #44   Spotlight this post!
Unread 10-12-2002, 23:07
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
bosch motors
so, if we used the Bosch gearbox......would that, say, lower our speed or reduce our torque compared to having a gearbox that fully switched gears using pneumatics and stuff like that?? because I'm not sure how powerful these Bosch motors would be compared to different gear ratios
It depends on the gearbox design you would use outside of the Bosch transmission. You can also find equations and charts on this site to help you determine the benefits and disadvantages of an external gearbox.
also, how would we design the Bosch motor to shift gears, if we were to use it as a shifting motor?? pneumatics?
Check the previous replies. Some teams use pneumatics, others use the servo motors in the kit. I would also highly recommend that you do a detailed check through the white papers of this site. There are many different designs here, so look around. My team is currently trying out the most recent dual motor transmission design, as it looks very promising.
  #45   Spotlight this post!
Unread 13-12-2002, 17:43
thanks for the help Alavinus the white papers helped a lot . However, I'm curious on how some of the gear shifting robots were able to shift on the fly?? how did they make the gears mesh properly? and if they don't mesh properly what are the chances of those gears being destroyed?
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
for fun and boredom mjt902 Technical Discussion 11 26-04-2003 14:11
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
drill motor transmissions nwagers Motors 16 29-01-2002 10:54
