Go to Post We don't require innovation; we simply encourage it. - Tristan Lall [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 09-12-2002, 00:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What was 1999's game?
Also, is there somewhere I can find out what all the past games were?
  #32   Spotlight this post!
Unread 09-12-2002, 09:05
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
1999 was the "year of the floppy" which was a funky gamepiece item that I can't really explain. It was also the first year of Alliances. I'm thinking Dean's hint refers to the alliance aspect (some sort of change to the 2v2 model), but it could be about the gamepieces, too.
Jeff Waegelin
  #33   Spotlight this post!
Unread 09-12-2002, 16:13
Johca_Gaorl's Avatar
Johca_Gaorl Johca_Gaorl is offline
Pwn3d
#0122 (NASA Knights)
Johca_Gaorl is an unknown quantity at this point
Send a message via AIM to Johca_Gaorl
http://www.nhgs.tec.va.us/first/99fi...99/TheGame.pdf
It's in there in the first couple pages.
DOX
At VT! Guess I'm unofficially part of 401 now...
  #34   Spotlight this post!
Unread 09-12-2002, 19:56
Matt Reiland's Avatar
'The' drive behind the drive
Anyone notice in the user manual that the new operator interface can display 'Team Number (4 digits were sent out to teams that have 4 digits says the manual), Channel, Voltage, & TADA User variable that you can set in your robot code. COuld be really useful if you have a special value you need to know such as a potentiometer!!!!
  #35   Spotlight this post!
Unread 09-12-2002, 22:28
Chris Nowak Chris Nowak is offline
Soudeska?
#0074
Chris Nowak is an unknown quantity at this point
Re: No drivers
Originally posted by Not2B
I agree with everyone who thinks the robot will run in autonomus mode for a while. The EDU robot default code makes reference to autonomus mode. It seems to be turned on and off from the FIRST computer at an event. It looks like sensors have become more popular lately.
I just don't know how it could be done...
Could it be.....
- first X seconds are auto
- last X seconds are auto
- You switch it into auto mode and score more points for every second you are in auto mode
- Do field elements emit signals?
- Will robots be required to carry signal emitters (like an inferred beacon)
What kind of sensors will we get? Gyro, IR, touch, stuff to build our own? (line followers, proximity, distance, etc...)
Lots of fun...
Running it in autonomous mode would make scouting and strategizing very intense because you would actually know how the robots would perform if you knew how they had performed in previous matches...the skilled scouter who knew the sensors and programming of the robots in the match might be able to predict the outcome if its totally autonomous or how the robots are going to end up when the leave autonomous mode. If this is the case, this is going to be extremely interesting.
MSN Messenger - chris_nowak91@hotmail.com
Team 74 - Top Seeded Team in Galileo Division
  #36   Spotlight this post!
Unread 09-12-2002, 22:47
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
more thinking.....
I did some more thinking..... and that's all it is... just me thinking...
BUT
Why wouldn't they let us have the default code until Jan 5th? Does that mean something FUNKY is going on in the default code? Something that HAS to be in the code, say, a FIRST event computer controlled item...... (like the light, or program start/stop)
Just doing my job to spread an autonomus panic among the programmers on my team and yours.
Brian Graham
  #37   Spotlight this post!
Unread 09-12-2002, 23:08
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Anybody care to press their luck?
http://www.chiefdelphi.com/forums/ve...tail&eventid=4
We're testing out the Ventures System again. This test event may be of interest to those of you who participated in this thread.
I promise not to accidentally delete the data this time
Brandon Martus
e-mail
  #38   Spotlight this post!
Unread 10-12-2002, 12:14
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
We got a 4 Digit Display, and we are only 3 numbers, so I dont know if thats fully accurate, or if they just messed up
Ricky Quinones
Director of Sales - VEX Robotics
  #39   Spotlight this post!
Unread 10-12-2002, 20:18
Matt D's Avatar
Matt D Matt D is offline
college time!
FRC #0254 (Cheesy Poofs)
Matt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to all
ours too...
I just saw my team's OI for the first time today. THough we are only a 3 digit team (254), it has 4 digits.
-Matt Durstenfeld
  #40   Spotlight this post!
Unread 10-12-2002, 20:22
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Re: ours too...
That's for the 4 diget teams such as 1089 .
  #41   Spotlight this post!
Unread 10-12-2002, 21:22
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
I have been thinking about what this years game will be, and I haven't decided exactly what it will be so I won't guess. I guessed last year and i was quite wrong. But there have been some main characteristics that have held true over tha past few years.
1. Robots start at point X, from there they move to point Y which is where the task is accomplished be it the moveable goals(2002), the bridge(2001) or the stationary goals(2000). Point Y is typically in the middle section of the field. From there, they must end the match at a certain point, Whether it be point Z or original point X, they must finish the match there.
2. There have been, for the most part, two types of robots per year.
*Power Robots, ie, hanging robots(2000), Balancing Robots(2001), and Goal Robots(2002)
*Finesse Robots, ie Ball Robots(2000), Big Ball Robots(2001), Ball Bots(2002)
As you can see FIRST does not want the same thing every year, but they do like some form of consistency in the games from year to year.
  #42   Spotlight this post!
Unread 10-12-2002, 22:10
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
this is purely speculation but.....
do you think that having the championship in a football stadium might have something to do with it? How bout a football like obsticle course that you would have to have your robot do automatically? probably not probable, but most certainly possible.
oh, and i want to see bowling pins in a competition...
have your programmers started to panic yet?
Where has all the fun gone?
  #43   Spotlight this post!
Unread 10-12-2002, 22:22
busy.
AKA: B. Slash Kamen
You're not alone. My dad says the same thing every year:
http://www.chiefdelphi.com/forums/sh...rtus#post75580
http://www.chiefdelphi.com/forums/sh...rtus#post85607
http://www.chiefdelphi.com/forums/sh...rtus#post67800
Brandon Martus
e-mail
  #44   Spotlight this post!
Unread 10-12-2002, 22:26
Joe Matt's Avatar
Is the whole Martus clan in FIRST Brandon?
Not to throw this off track.
  #45   Spotlight this post!
Unread 10-12-2002, 22:29
busy.
AKA: B. Slash Kamen
Yes?
Brandon Martus
e-mail
What changes to this year's game...? DougHogg General Forum 16 20-04-2003 15:35
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
Long post - this year's game was tough - here's why: archiver 2001 7 24-06-2002 03:31
i didnt like this years game....please read archiver 2001 19 24-06-2002 03:23
Do you think this years game will be... Brian Savitt General Forum 26 09-12-2001 22:43
