Go to Post You earn what you work for. - Akash Rastogi [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 15-12-2002, 16:12
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
What exactly do you mean by "doesn't work"?
RoboEmu seems to process it just fine. If you want to try it out, you will need to add eight 127s to the end of the serout to make it the same length as the full RC serout and you will need to add a colon after exit_drive_r_test on line 405 to make RoboEmu recognize it as a label.
Just click the checkbox for sw5 and then play with port 1 to see the changes.
If you want some more help, try the following tests on your robot and let me know what happens. I'm guessing that one of the motors just needs to be reversed or you need to swap which PWM drives each motor. Here's my list of tests:
What happens when you push the joystick straight forwards? straight back?
When you move it all the way to the left? to the right?
In the upper-left corner? Lower-right?
--Rob
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
