Go to Post If you want to attach a name to your post then I might actually consider your opinion. - Gregor [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 29-12-2002, 23:31
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Wheel Hub Connectors for Skyway Wheels
In the past few years one of FIRST suppliers has offered premade plastic hub inserts for the Skyway wheels. I thought it was Small Parts but they don't appear anywhere on their website. Skyway isn't showing them either. Anybody know the source and whether they are still available?
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 29-12-2002, 23:36
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I am almost 100% sure they were in Small Parts also. Maybe they are not making them anymore since the aren't our supplier this season?
2001-2004: Team 100
2006-Present: Team 254
Unread 30-12-2002, 10:11
Matt Reiland's Avatar
'The' drive behind the drive
THere is an extra section in the manual that contains extra parts that are not in the regular Small Parts manuals. Appendix D
Looking at it the part # is
FIR-DC01 Wheel hub kit for 2 wheels
The coupler for the BOSCH drill is
FIR-DC02
Hope that helps
Matt
Unread 30-12-2002, 13:40
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
The wheel mounts and drill motor couplers were supplied by Small Parts. I hope that someone will at least post a design so that teams can build these, if they aren't supplied.
In our first year, they were not available and we had all manner of difficulties with mounting the drill motor to the wheels. I think many other teams had these same problems, hence the couplers.
We actually made a hub piece last year so that we could use the skyway wheels. We knocked out the bearings and machined some of the spokes down to give us flush surfaces. Although I made the parts on a rotary table, they can mostly be done on a lathe with a template for the hole pattern made on a mill.
If anyone is interested, I'll try to pull up the drawings and post them.
Then again, who knows? We may not have drill motors or skyway wheels in the kits this year.
Andrew
Team 356
Unread 30-12-2002, 18:07
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Cool SPI supplier
I too confer that they were supplied by SPI and they usually were listed on a supplement to their catalog in the kit of materials.
I received the email blast about the new supplier, but does that mean that Small-Parts inc. is no longer a sponsor??
Unread 01-01-2003, 13:06
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
Anyone know for sure ?
Unread 01-01-2003, 19:36
FOR SURE they were ordered from small parts and this was the schematic
Unread 01-01-2003, 19:37
And these are the specs that were requested
Unread 01-01-2003, 20:10
RebAl's Avatar
no are they sure about small parts isent our supplier this year
Unread 02-01-2003, 00:14
Cory's Avatar
AKA: Cory McBride
They are not our main supplier any more. MSC took their place. I dont know if they will still be affiliated with FIRST. Anyone else know?
2001-2004: Team 100
Unread 02-01-2003, 00:53
RebAl's Avatar
Who is MSC and how are you sure?
Unread 02-01-2003, 01:13
Cory's Avatar
AKA: Cory McBride
MSC is a very large industrial supply company. You can vist their website at http://www.mscdirect.com This http://www.chiefdelphi.com/forums/sh...threadid=15512 thread has the specifics
Cory
2001-2004: Team 100
Unread 05-01-2003, 04:41
SiliconKnight's Avatar
SiliconKnight SiliconKnight is offline
#0824 (SWAT Robotics)
SiliconKnight is an unknown quantity at this point
Send a message via ICQ to SiliconKnight Send a message via AIM to SiliconKnight Send a message via Yahoo to SiliconKnight
I'm actually glad to see Small Parts go. They are *nifty*, but I wince at their prices and this little "exclusive deal" they had with FIRST had made them... well, IMHO arrogant. They *lost* 2 of our orders last year, and we had REALLY crappy customer service from them. Personally, I never would buy anything from them for my team EVER AGAIN - if they were our "official" supplier this year, I would have bought parts elsewhere after verifying that it's in the SP catalog.
Unread 09-01-2003, 16:17
ark_1230's Avatar
ark_1230 ark_1230 is offline
What the Random?
AKA: Andrew
FRC #3138 (Dayton Innovators)
ark_1230 is an unknown quantity at this point
Question Extra Hubs?
Does any team have any extra hubs they are willing to part with?
**Also I spoke with Small Parts on the phone and the hub kit is no longer available.
The hubless sprockets which pair to the hubs are still available, though I couldn't find them listed in the catalog online.
Andrew Kraemer
Team 979
Dayton Dominators
Unread 09-01-2003, 18:47
Maureen Maureen is offline
Maureen is on a distinguished road
Talking hubs for caster wheel
It is probably best that they are no longer available. The traction requirements of this and last year's game pretty much rule out using those caster wheels. Order some keyed bearing hubs on your choice of skyway wheels. Order some keyed roller chain sprockets from MSC and you don't need to mount a sprocket to the wheel hub. Much better mechanically and much easier to mount and change out sprockets.
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
wheel hub kit and sprocket archiver 2001 7 23-06-2002 23:27
