Go to Post Chief Delphi's Greatest Hits vol. 47: Overreactions to Q&A responses - Lil' Lavery [more]
Unread 23-12-2001, 11:22
FRC Key Volunteer Trainer
AKA: CrazyNate
I know with the older versions, it did allow you to install 3DSMAX on multiple machines for the purposes of network rendering, which does NOT require a hardware lock. With the older, hardware-locked versions of 3dsmax, you needed a hardware lock for each machine where you were actually going to be using the software for designing the animation, but could install on as many as you wanted when it came time to split up the rendering work. So, in a nutshell...
Installed 3dsmax + hardware lock = full version
Installed 3dsmax + no hardware lock = net render workhorse only
Nate Smith
nsmith@smythsoft.com
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
