Go to Post These awards aren't easy to get, and if a team deserves an award, they deserve to be cheered on for it. - tckma [more]
Unread 05-01-2003, 17:58
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Re: traction questions
Originally posted by Aonic
ok... so i've got a few questions:
1. if you have a foam thingy on the bottom of your wheels, and the weight of the robot presses it into the mesh so part of it protrudes through, is that in violation of the rules?
Until further clarification, yes, it is in violation of the rules. If objects are put through the mesh for the purpose of grabbing, the holes could get deformed.
However, this rule is a bit vague, because it doesn't define the maximum extent of the pertrusion. Any circular wheel will pertrude into the opening of the mesh, but only a little bit. My best guess is that most traction material will be fine, they just don't want people sticking a pneumatic rod through the mesh opening to hold their robot's position.
2. i saw a robot last year that used a belt with metal upside-down 'U'-shaped things to grab onto the carpet... that isn't allowed this year, right?
Correct. Carpet-metal interatction is prohibited by the rules. This inclides the ever popular chain-cleat treads.
3. our mentor used some polyurethane foam stuff with some traction pattern cut out of it attached to their wheels last year. is that not allowed this year? it says that the outer surface of off-the-shelf wheels may be modified by removing tread material only.
There's no reason why you cannot use the polyurethane, but you will have to manufacture your own wheels from stock, and then adhere the material to them.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Materials for traction parteyboy10 Rules/Strategy 1 13-01-2003 21:15
Q&A Traction Question answer Cory Technical Discussion 4 09-01-2003 06:37
New member, new team, questions. Frank(Aflak) General Forum 21 14-12-2002 06:59
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
Legal way to remove bottles? and other questions jrukes Off-Season Events 4 15-10-2001 22:35
