Go to Post Must...squish....bugs... :p - nighterfighter [more]
Unread 05-01-2003, 23:04
Gope Gope is offline
#0016 (Bomb Squad)
Gope is on a distinguished road
Visual Basic - Drag and Drop
I am working on a game mimicking score simulator where you can drag around robots and bins and get scores, but i'm haveing trouble with the drag and drop part.
When I only set the forum to allow movement for one object
Source.Move X, Y
Then things work fine, but when I set the forum to allow movement for two or more objects
Source1.Move X, Y
Source2.Move X, Y
Then when I drag either object Source1 is in the drop positon and Source2 is nowhere to be found.
I'm clueless, and can't find a tutorial or forum with the answer, PLEASE HELP!!!!
College and its wonders. First year and alot of other FIRSTs.
Unread 05-01-2003, 23:56
iscrc2 iscrc2 is offline
#0568 (Nerds of the North)
iscrc2 is an unknown quantity at this point
on a form not forum right? Are you setting both objects to drag mode=automatic?
Unread 06-01-2003, 00:14
Umm Errr...
i am considering making a web based scoring simulator for everyone. Tell me how ur sim goes. Can u post it when ur finished¿
1139 Alumni
Unread 06-01-2003, 00:18
#0016 (Bomb Squad)
This is my program, except for the positioning junk, it dosent work in vbManual or vbAutomatic.
Private xoffset As Integer
Private yoffset As Integer
Option Explicit
Private Sub ba_MouseDown(Button As Integer, Shift As Integer, X As Single, Y As Single)
xoffset = X
yoffset = Y
ba.Drag vbBeginDrag
End Sub
Private Sub bb_MouseDown(Button As Integer, Shift As Integer, X As Single, Y As Single)
xoffset = X
yoffset = Y
bb.Drag vbBeginDrag
End Sub
Private Sub Form_DragDrop(Source As Control, X As Single, Y As Single)
bb.Move (X - xoffset), (Y - yoffset)
ba.Move (X - xoffset), (Y - yoffset)
End Sub
ya, if i finish this, i'll pass it out to whoever wants it.
Unread 06-01-2003, 00:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What I'd like to see is a version with 4 "players" just like the real game so 4 people can use the program at once. This would be okay with the current game simulator too. Am I making sense?
Unread 06-01-2003, 00:53
#0016 (Bomb Squad)
The final version will have 4 robots...i just put up the code(only has 2 bots now) in hopes that someone would see what i'm doing wrong.
Unread 06-01-2003, 00:54
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
Heres how to fix
umm ya, just do this
Turn DragMode automatic whatever in the properties window, right then on the place where it lands, use the drag drop event and get the object that was dropped with the parameter.
I would give you a more accurate description of how to do this but I was too lazy to open VB. This should work, if it doesn't then I'll tell you how to fix it, or send you a sample.
DragMode = Automatic
Object receiving event DragDrop, in that event do your stuff
k
Bleah, I dont use MOVE either
I jsut do object.left
object.top =
because if you use X and Y, it does placements based on your desktop I think ya thats it
sry, just a cheap lazy message trying to fix some c++ bug
- Ryan Waliany
R
Unread 06-01-2003, 00:59
#0016 (Bomb Squad)
I'm not really following you. I'm trying to simply drag an objecct and make it stay where it was droped, I can manage to do it with one objeect, but not with multiple ones.
Unread 06-01-2003, 01:06
rwaliany's Avatar
R
Hrmmm
What do you mean one, and not others? Do you have Aim, Icq, MSN, or Yahoo. I could probably explain it better on one of those.
Aim: Ryan Waliany, Icq: 11032544, MSN, ryan@scv.net, yahoo Ryan_waliany
R
Unread 06-01-2003, 01:14
rwaliany's Avatar
R
Drag Drop
Source code of VB proj which does it...
File Type: zip sample drag.zip (661 Bytes, 48 views)
R
Unread 06-01-2003, 09:38
josh_johnson josh_johnson is offline
#1020 (Indiana Prankmonkeys)
josh_johnson is an unknown quantity at this point
Send a message via AIM to josh_johnson Send a message via Yahoo to josh_johnson
From what you have said, it appears that your code may be moving both objects when you only click and drag one. The destination would be in the same place with one object completely covering the first.
Unread 06-01-2003, 09:42
#0016 (Bomb Squad)
thanx every1 who helped me, i finaly fixed the problem
