Go to Post Did our Jaguar swallow a chipmunk, or is something else going on? - Tom Line [more]
Unread 06-01-2003, 00:20
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
The New PBASIC
OK, I've figured it out, and in case anyone wants to get started, here are the new commands and the ways you can use them. Use at your own risk as it is possible Parallax will never release the updated editor and your code will be worthless:
1. NEW IF SYNTAX! There's two, actually.
The first is:
if condition then
code to execute if condition is true
else
code to execute otherwise
endif
The second is:
if condition then statement
These should make people happy as if statements now work like you're used to from C/Java/etc.
2. SELECT. Almost exactly like C's switch:
SELECT variable/expression
CASE value1
commands
CASE value2
commands
ENDSELECT
3. DO...LOOP. Like do/while.
Either the DO or the LOOP can be followed by the keyword WHILE or UNTIL. Putting it on the DO will cause it to be checked before executing any of the body. Putting it on the LOOP will cause it to be checked only after the body has been executed at least once. Examples:
DO
commands to execute
LOOP
-or-
DO WHILE condition
commands to execute
LOOP
-or-
DO
commands to execute
LOOP WHILE condition
There's one other new one, but I can't remember what it is at this time. Something similar to BRANCH, if I remember correctly.
Hope that helps.
--Rob
P.S. RoboEmu 1.09 will support all these new commands and should be done tomorrow afternoon.
Unread 06-01-2003, 08:29
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Thanks Rob
Now all we need is First/InnovationFirst/Parallax to get their "stuff" together and get us working editor/compiler software.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 06-01-2003, 09:27
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
So, in other words, PBASIC is becoming more like standard BASIC. I like it. Now, if we could just add a few more variables, floating point math, and negative numbers, we'd be all set...
Jeff Waegelin
Unread 06-01-2003, 13:13
InnovationFirst's Avatar
InnovationFirst InnovationFirst is offline
Official FIRST Supplier
InnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond repute
Exclamation Breaking News from Parallax
We just received news from Parallax that the release of PBASIC 2.5beta will be Friday, January 10th. The files will be available on www.innovationfirst.com (not Parallax). We apologize for the delay. Please do NOT contact Parallax, as this will just delay the release.
Unread 06-01-2003, 15:01
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
The problem with negitive numbers is that unless they make it so that -127 is the new full-reverse number, then it will totally screw up your robot. Think of it this way:
127 = Full Forward
0 = Nothing (stopped)
-127 = Full Reverse
This above would have to be the new way to control the speed of your robot.
Note: This is how our controls specialist (I think you can call him) told me about the speed.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 06-01-2003, 16:06
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Floating point math is not a problem with the pbasic language, but rather with the BASIC stamp itself. We would require a much more expensive microprocessor if we wanted to do floats. This is also the reason we can't have more variables, there is only so much RAM space.
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 07-01-2003, 16:33
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
The changes seem better, it looks like the newer versions are starting to have a more uniform programming style. Most languages that I have worked with have used that kind of syntax.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 07-01-2003, 20:17
Morgan Jones Morgan Jones is offline
Morgan Jones is an unknown quantity at this point
Something rbayer didn't mention is the TCASE (Through CASE) command under SELECT. A TCASE is evaluated even if the previous CASE (or TCASE) evaluated as true. This would be like leaving out a break command in C/C++. Although no examples comes to mind at the moment, this feature may prove useful.
http://groups.yahoo.com/group/basicstamps/message/27596
Morgan Jones
Team 578: Fairport High School/Gleason Works
Unread 07-01-2003, 20:44
I knew I was forgetting something! Anyway, the other new one is ON. It's almost identical to BRANCH, except you can use it to do gosubs instead of just gotos.
Unread 07-01-2003, 20:57
AKA: Eric Hansen
I'm just trying to see if I understand you right, you mean something like "if p2_y > 30 on 40 then gosub Exit"?
Y!: synsoflife
Unread 07-01-2003, 21:02
No. It's like
ON counterVar GOSUB label0, label1, label2, label3, label4, label5
There may be brackets in there, but I don't remember.
Anyway, if counter counterVar has the value 0, it will GOSUB to label0. If it's 1, GOSUB label1, etc. It's identical to BRANCH, except you can do a GOSUB instead of just the equivalent of GOTO. Note that you can similuate a BRANCH exactly by doing
ON counterVar GOTO label0, etc.
As for the code you posted, PBASIC now supports what I like to call one-line-ifs, meaning you can do
if p2_y>30 then gosub exit
Similarly, you can do stuff like:
if (p1_y < 140 AND p1_y > 117) then p1_y=127
Mmmm... tasty.
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
RoboEmu 1.09 (supports PBASIC 2.5) rbayer Programming 22 21-01-2003 17:22
PBASIC Loop Speed? archiver 2001 3 23-06-2002 23:46
