Go to Post Our Digital Sidecar can attract metal chips from distant planets. - electroken [more]
Unread 05-01-2003, 22:45
carlye carlye is offline
#0973 (Greyhound Roevolutionary Robotics)
carlye is an unknown quantity at this point
robot touching a stack of bins
say there are 3 stacks of 7 bins on YOUR carpet, and YOUR robot is touching one of the bins in one of the stacks...does the entire stack not count (7 bins) or does only the one bin that the robot is touching not count (and the other 6 do)?
Unread 05-01-2003, 22:47
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
the stack does not count, all of it
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 05-01-2003, 22:49
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
The whole stack is worth zero. Here is the rule:
SC8 When determining the base score for the alliance, the referees will evaluate the containers
with the following criteria:
A container “in” a Scoring Zone is worth one point. A container will be determined
to be “in” a scoring zone if at least some part of the container is touching the colored
carpet that defines a scoring zone or is supported exclusively by:
· Other containers in that zone;
· An opponent’s robot.
All containers in the tallest stack located in the scoring zone (the “multiplier stack”)
are worth zero points. Containers in additional stacks of the same height will be
scored normally;
!!!!!!!If ANY part of your own alliance’s robots are in contact with ANY container in a
stack (alone or in a multi-container stack), ALL containers in that stack will be worth
zero points;
Opponent robots in contact with containers in the alliance scoring zone will not affect
the determination of the base score;
A container may touch the field border.
Unread 05-01-2003, 23:02
thank you Bduggan04 that was a very good answer.
Unread 05-01-2003, 23:15
Antonio Antonio is offline
Antonio is an unknown quantity at this point
so say if you had the 3 different stacks each 7 tubs high and say one of the robot is touching one of the stacks, that stack would not qualify as the multiplier, but can it be counted as the base scoring?
Unread 05-01-2003, 23:18
Mike537Strategy Mike537Strategy is offline
#0537 (Charger Robotics)
Mike537Strategy is an unknown quantity at this point
No, thats what the rules above say. Read the rule that starts with the multiple !s.
"Charging into the future, one game at a time." - Team 537 motto
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If you are touching it AT ALL then it counts fornothing
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 05-01-2003, 23:26
alright thanks
Unread 05-01-2003, 23:54
Mark Garver's Avatar
Mark Garver Mark Garver is offline
AKA: Garver
Mark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to behold
Send a message via AIM to Mark Garver
What if..
Going to stir things up with this one,
What if you have two stacks of 6 with another box on top of box and the robot is only touching the highest box? Do both stacks of 6 count or only 1? :-)
Unread 06-01-2003, 13:37
JTH JTH is offline
#1447 (Panther Robotics)
JTH is an unknown quantity at this point
Send a message via AIM to JTH
Here's a situation that follows along the the lines of this discussion.
According to SC8, a container is in the scoring zone if it meets these criteria:
A container “in” a Scoring Zone is worth one point. A container will be determined to be “in” a scoring zone if at least some part of the container is touching the colored carpet that defines a scoring zone or is supported exclusively by:
So, if an opponent is holding a crate, it can count as a scorable crate. Note that it doesn't differentiate where the box is held, or where the robot is, but the fact that it is entirely supported by the opponent robot makes it worth points.
According to SC9,
Only stacks located “in” a scoring zone (as defined in SC8) are eligible to become
multiplier stacks;
Opponent robot contact with a stack will not affect multiplier stack eligibility.
The way that I read it, because a crate being held by the opponent robot can be counted as being in the scoring zone, it can also be counted as a stack. So, if an opponent, anywhere on the field, is carrying a crate 20' in the air at the end of the game, that's a 20' stack for your alliance (15.74 SHU=16x multiplier)!
Unread 06-01-2003, 13:51
Johca_Gaorl's Avatar
Johca_Gaorl Johca_Gaorl is offline
Pwn3d
#0122 (NASA Knights)
Johca_Gaorl is an unknown quantity at this point
Send a message via AIM to Johca_Gaorl
Ahhh! Loopholes! I feel sorry for FIRST...
I would think the opposing robot holding it would only count if they were in your scoring zone.
DOX
At VT! Guess I'm unofficially part of 401 now...
Unread 06-01-2003, 13:55
JTH JTH is offline
I would have thought it only counted if the opponent robot is in your scoring zone, or if the box was in the "volume" of your scoring zone. The first few times I read it, that's what I assumed. However, the rule only says that it is entirely supported by the opponent robot for it to count.
Unread 06-01-2003, 14:16
tatsak42's Avatar
tatsak42 tatsak42 is offline
#0159 (Alpine Robotics)
tatsak42 is an unknown quantity at this point
Send a message via AIM to tatsak42
I think it's just if the opponent is holding it inside your scoring zone. Otherwise, that would be a huge loophole. Say someone was trying to get one extra bin before ending on the top of their 13 stack. But time runs out, they're not touching their bins, and it's being held at a height of 15 bins. Suddenly you get that multiplier of 15? I don't know, but that seems weird.
Maybe they just forgot to retype "in that zone" after the opponents thing
She's like a sleepy little ninja!
Unread 07-01-2003, 22:57
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
See Team Update #1. This question is answered in the clarified version of Rule SC8.
-dave
Unread 09-01-2003, 16:55
JTH JTH is offline
The updated SC8 and SC9 still allows a opponent carried crate to be counted as a stack.
However, the update does mean that the opponent must be "in" your scoring zone. I think this means they are touching your colored carpet.
It would make a very interresting opportunity for pushing up scores if two tall-arm robots are on opposing sides and decide to team up to make huge points for each other. Of course, one side will receive more benefit than the other, but a huge multiplier might to push up your average might be worth it.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Beantown Blitz game change? Erin Rapacki Off-Season Events 31 18-06-2003 12:39
Does a stack count if the opponent's robot is touching it? Jessica Fusher Rules/Strategy 1 08-01-2003 22:04
Arm touching other robot Erinn888 Rules/Strategy 2 06-01-2003 09:58
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
