Go to Post Remember, only YOU can set a good examples for rookies to search CD first before asking questions or responding!! - Foster [more]
Unread 05-01-2003, 14:12
Mimi Brown's Avatar
Mimi Brown Mimi Brown is offline
#0128 (The Botcats)
Mimi Brown is an unknown quantity at this point
Send a message via AIM to Mimi Brown Send a message via Yahoo to Mimi Brown
Urgent...Modifying this years drill motors
At first glance, this years motors are more than a little different than last years (which i knew inside out) So, i was wondering how vital the removal of the back-drive pins on this years motors would/will be.
Also, assuming i will be removing them, what would be the best way to open this years motors up to get to the pins?
any (speedy, please) help is greatly appreciated!
~Mimi
Unread 05-01-2003, 15:37
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
I have one gear box about 50% disassembled. These things are a lot tougher to take apart and not break than previous models.
So far...
On the first stage, there are two plastic tabs 180 degs apart. Pull them out and pull the first stage off.
The first stage shim and the first internal (ring) gear are pushed into the plastic grooves. You can pry the shim out and then get the internal gear out by tapping the stage on a hard surface.
The metal springs on the shifter can be pulled out with a pair of pliers and the shifter will slide off.
The second stage gears come out easily at this point.
The clutch shell (the thing with the numbers on it is retained by three double tabs at 120 degress apart. I put the shifter into its relaxed state. Then, I pushed in on one double tab with my fingernail and pushed up on the clutch shell. Rotated to the next tab and repeated, rotated to the next tab and repeated. Eventually by going around the circumference, I was able to push off the clutch shell.
I almost have the second stage off, although there is a non-obvious tab or something holding it together. I had to stop before I starting ripping tabs off (I do want to reassemble the thing later, after all).
Andrew, Team 356
Unread 05-01-2003, 16:20
Woohoo! Second stage is off.
The second stage comes off easily. You just have to twist it (I think clockwise) and pull. Once you have this stage off, the anti-back drive pins are right in front of you.
Still no luck with the clutch, but I'm going to try to get it from the back side.
Andrew
Team 356
Unread 05-01-2003, 16:26
Mimi Brown's Avatar
#0128 (The Botcats)
We just figured that out too...one of our engineers had a "happy accident"...its also very easy to just do this from the start without disassembling anything else, which is how we did it. so...do you suggest removing the back drive pins?
Unread 05-01-2003, 17:22
From everything everyone has told me in the past, it is a good thing to remove the pins. I think there is a recommendation in the manual this year that you do it. Or maybe the recommendation is in a forum (can't remember).
I also recommend making a ring to disable the shifter and insert it into the gearbox. Unless you're planning on using the shifter that is.
Andrew
Team 356
Unread 06-01-2003, 01:30
Andy A. Andy A. is offline
Getting old
FRC #0095
If you don't remove the pins, every time you stop applying power to the motors, your bot will come to a very abrupt stop (assuming the drills are on your drive train). Its a lot like heading down the road at 10 mph, and slamming the breaks on. If your not wearing your seat belt, you keep moving at 10 mph into the dash. Now imagine doing that every time you had to stop at a light. There wouldn't be enough asprin in the world to cope with that headache, and your car would probably suffer to.
Same thing happens on a bot. Things will want to keep moving, the battery for example. Its a strain on the drive train espically.
So unless you are using the drills in some application that really needs to avoid back driving (some insanley powerful arm for example) or not using the gear box, its best to take them out. You will kill your drive train with them still in, and even if you don't it'd be real obnoxious to drive.
So ya, get the pins out. They make nice tropheys...
-Andy A.
Unread 06-01-2003, 10:14
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
-Andy A.
Wouldnt that also cause a jump in the amperrage? i mean if you are going from a speed to an instant stop, you would have to experience that right?
Bad
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 06-01-2003, 11:13
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Hold on
You may not have to remove these pins. Sure, the drill motor has more power, but our team has never really worried about removing the pins in order to save the gearbox from being ruined, like many other teams believe.
If a team drives their robot reasonably and mount the gearbox correctly, you may want to keep your pins in your gearboxes... don't just remove them because you think you have to in order to save the gearboxes.
We have used the old gearboxes during 4 or the past 5 years, while using metal treads (no slipping on carpet), and we only removed them for one of those years (2001). During those years, we blew a few gearboxes (2 in '99, 0 in '01).
Remember in 2000? If you wanted to stay on the ramp, then having these pins in place was a good thing... if you removed them, then you saw your robot coasting off of the ramp at the end of the match.
I'm just saying that don't simply remove these pins before you think it will benefit your team.
Andy B.
Unread 06-01-2003, 13:26
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Hold on
If you are on the top of the ramp you will want the pins in. That way a robot without pins trying to get up the ramp at the last second won't knock you off when they go coasting over the top.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 06-01-2003, 19:26
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Back at 2000, we put the pins back into the drill transmissions for the exact same reason... Our robot slipped down the ramp one match, and we never want that to happen that year again. During that year, those pins never break in the transmission.
However, if the pins do break, they could damage your tranmission so much that the failure will render it useless. So, every time those pins break, you may have to buy a new transmission.
Depending on your system, your pins might or might not break. My advice is, test your drive train hard before you ship the robot. Run it against walls, come to sudden stops, go on the ramp and down again, etc. Do different trails with the pins in, then take them out and see what happens. If the pins are ok even after a lot of testing, then I think it would be ok to keep them in during the competition.
This year is a little different than 2000, because the top of the ramp is flat instead of a peak, and to get the 25 points you got to stay on completely. So, if you are on top completely, you won't have to worry about sliding down. If you are fighting your way onto the top, your motor are moving anyway, so you won't need the pins to keep your robot on the ramp.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 06-01-2003, 22:50
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Heh...
One of our teachers picked it up and the thing decided to break into two pieces...the pins both fell out and all of us students were like "WHERE DID THOSE COME FROM?!"
Well...after about 1/2 hour, we got them back in using guess-and-check methods when our head teacher walks in and informs us that we probably don't even need them!
Oh well...at least we got to get a look inside it
Unread 07-01-2003, 06:32
SiliconKnight's Avatar
SiliconKnight SiliconKnight is offline
#0824 (SWAT Robotics)
SiliconKnight is an unknown quantity at this point
Send a message via ICQ to SiliconKnight Send a message via AIM to SiliconKnight Send a message via Yahoo to SiliconKnight
Seems like that the ring to lock the motor tranny in high or low (after a quick disassembly and measuring session) should be roughly 1.520" OD, x 1.300" ID x 0.228" thick. You'll need to bore out part of it to clear the gear tooth molded into the inside of the stage 2 body.
I do not see a easy way to take out the clutch shell Last year's drill motor design the clutch can be locked out by removing the double-stack ball bearings and replacing with M6 set screws; however if you put the clutch into drill mode, 2 pieces of metal rises up out of the plastic shell to positively lock the clutch ring from slipping. All in all, this is one *MEAN* gearbox.
I love to engineer bigger and better toys, but aside from a lock-out ring, I don't know how much modding I am willing to try on this gearbox. Well, I also dont' want to break it, seeing how it's so new, replacements would be difficult to come by.
Anyone know what screw pitch the shaft is at? I don't have a set of thread gages handy.
-=- Terence
Unread 07-01-2003, 12:51
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
But if you don't make it up, you wouldn't want your robot to coast back into your scoring zone and knocking over your own scoring stack
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 07-01-2003, 15:22
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
-Andy A.
I've seen a team that shot them out the side of the casing because of the way their drivetrain was. If you do leave them in, you should program the robot to decelerate or train your drivers to slow down.
Unread 07-01-2003, 17:14
Antonio Antonio is offline
Antonio is an unknown quantity at this point
would we be able to construct a high speed shaft onto the drill motor similar to the one designed by Dr. Joe on the white papers?
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
Should FIRST include Bosch Drill Motors in Next Years Kit of Parts mtaman02 Motors 9 05-07-2002 16:32
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
