Go to Post Seemed like a solid plan in my head. - davidthefat [more]
Unread 26-12-2001, 17:52
Ydnar's Avatar
Ydnar Ydnar is offline
#0932 (Circuit Chargers)
Ydnar is an unknown quantity at this point
Send a message via AIM to Ydnar
Post Can you use inventor files with 3DS Max?
Hi, i was busy working on animating things early on and i came to a situation, there is no way i know of to use what i made in inventor 5 with 3D studio max 4.0, if you can help me it will be greatly appreciated, i think you should be able to use what you made in 3d studio max i just don't see the way to...
-Come and go, and rise and fall with glory, maybe one day i'll be famous too
Unread 26-12-2001, 23:22
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
Arrow Export Inventor to 3D Studio
I've only tried this with Inventor 3, I haven’t had time to work with our copy of Inventor 5, but It should be similar in 5.
In the file menu, chose "Save Copy As...”, and for the file type choose IGES (*.igs,*.ige,*.iges). You can import these into 3D Studio 4, and it I believe works for all 3D Inventor drawings.
It imports the files as NURBS surfaces which you can convert to whatever, and you'll lose the Inventor animation.
Unread 28-12-2001, 12:24
Ydnar's Avatar
Talking
Wow, it worked, this will make things a LOT easier when it comes to animation time so we can make our designs in autodesk inventor then toss it in 3Ds Max and use it for parts of it. THANK YOU...
Unread 05-01-2002, 17:00
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
watch out for inventor objects in your animations though. a simple ball has thousands of faces. i used inventor models in my animation last year and it was a nightmare... rendering is awful with them. unless someone can tell me how to lessen the # of faces or if inventor 5 lowers the face numbers when you export to iges... i havent used inventor 5 with max yet. i'll probably check it out when my team comes back with the kickoff kit.
Unread 10-01-2002, 14:23
Robby O's Avatar
Robby O Robby O is offline
no team (Volunteer)
Robby O is an unknown quantity at this point
Send a message via AIM to Robby O
And the wise man say...
Always use the optimizer, and your models will be many polygons lighter, my son...
Optimize is a modifier I learned all about in my sophomore year, my first year on the animation team of 108. AFTER our animation was submitted. I had a huge count on merely the terrain which was made of a massive patch grid. Something around 10000+ polys. Not good in the times of MAX 1.2 and 200mhz pcs being tops.
But basically optimize cuts down on your polygon count, while doing its best, according to spinners you set, at keeping the original model intact. In many cases, models can be cut down to fractions of what thier original count was and still look beautiful. Not to mention you can have differing poly counts for the renderer and the viewport, meaning faster working with cruddy looking models that render quite well. I think you can only use this on polygonal objects, however I will have to experiment now.
Read through the MAX Online Help and books for more detailed info.
-Robby O
FIRSTanimators Moderator
oshortwan@hotmail.com
PS: I currently have to use Kinko's internet connection so my communications will be varied, however look for me to be on quite often as I am not in school this quarter. Oh, and did everyone leave FIRSTanimators for the Chief Delphi boards?? Just curious B^P.
-Robby O
"If I had it in me
To stop these random thoughts
And non-stop dreams
I could deal with this
Non-stop spinning world" -Less Than Jake
Bitmaps as texture in 3ds max? BC1022 3D Animation and Competition 3 28-01-2003 18:32
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Another 3ds max "Key" Jack 3D Animation and Competition 7 09-05-2002 21:19
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
