Go to Post Brandon, your amazing! CD media will rock my socks off more then DS&K! :p Ok, maybe I won't go that far. - Kyle Love [more]
Unread 07-01-2003, 01:42
Jferrante Jferrante is offline
Jferrante is an unknown quantity at this point
Send a message via AIM to Jferrante Send a message via Yahoo to Jferrante
Question Change to Initializing Inputs and Outputs
In the section Initialize Inputs & Outputs I have noticed that all the pwm's which are normally set to start at 127 are totally missing for this years default code. Did anyone else notice this? Was the starting value necessary or was that just extra stuff that really wasnt needed?
Unread 07-01-2003, 02:00
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
err
I would be too scared to try the program without it. It might work. It might not. I know if your NOT using the new RC you have to initialize them or you might get some unwanted feedback, like a kick.
But yeah, if first could give us a default code when there isn't a working compiler, I think there is a good chance that we still need the initialization and they just forgot it.
Serin should overwrite any variables that are in its call, otherwise set it to an arbitrary ZERO(0 or 127).
R
Unread 07-01-2003, 10:25
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
I assume you are referring to the fact that the Serout now only has 14 arguments instead of the old 18? In that case, it will (and always has!) be just fine. If you don't output a variable, the Output uP will just set them to 127.
--Rob
Unread 07-01-2003, 11:13
--Rob
I hadn't even noticed that (I only edited serout for tank drive, other than that I leave those alone).
I was referring to the following lines not present in this years default program:
p1_x = 127 'Port 1, X-axis on Joystick
p2_x = 127 'Port 2, X-axis on Joystick
p3_x = 127 'Port 3, X-axis on Joystick
p4_x = 127 'Port 4, X-axis on Joystick
p1_y = 127 'Port 1, Y-axis on Joystick
p2_y = 127 'Port 2, Y-axis on Joystick
p3_y = 127 'Port 3, Y-axis on Joystick
p4_y = 127 'Port 4, Y-axis on Joystick
p1_wheel = 127 'Port 1, Wheel on Joystick
p2_wheel = 127 'Port 2, Wheel on Joystick
p3_wheel = 127 'Port 3, Wheel on Joystick
p4_wheel = 127 'Port 4, Wheel on Joystick
'p1_aux = 127 'Port 1, Aux Analog
'p2_aux = 127 'Port 2, Aux Analog
'p3_aux = 127 'Port 3, Aux Analog
'p4_aux = 127 'Port 4, Aux Analog
It used to be directly below this:
'---------- Initialize Inputs & Outputs --------------------------------------
Out7 = 1 'Basic Run LED on RC
Out8 = 0 'PWM1 LED - Green
Out9 = 0 'PWM1 LED - Red
Out10 = 0 'PWM2 LED - Green
Out11 = 0 'PWM2 LED - Red
Out12 = 0 'Relay1 LED - Red
Out13 = 0 'Relay1 LED - Green
Out14 = 0 'Relay2 LED - Red
Out15 = 0 'Relay2 LED - Green
now its not there. I was wondering if I needed to add it or if the robot would run fine without it
Unread 07-01-2003, 11:36
Those are actually fairly worthless. Any variables you are inputting get read in at that first Serin, overriding anything you choose to initialize them with. As long as you still have the VAR statements (ie p1_x VAR byte), you'll be just fine.
