Go to Post "It's not a bug, it's an unlisted feature." - Barry Craig [more]
Unread 30-12-2001, 20:23
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
Video on the web
Whatever you do, you can usually just post the final file as a direct link. Depending on the format, it will download or stream automatically.
What's the file extension? If it's a .mov , you can probably just post it (check the file size to see if it's reasonable.) If it's a .avi, though, you're going to have to compress it, as it's probably huge; too big even for a download.
What's the file extension, and how big is it?
The best compressor is the Windows Media 8 encoder (part of the 7.1 kit.) Quicktime has one too, but it's not freeware and not as good, though it's easier to use.
The Windows Media encoder is a rather complex bit of software, so unless you know someone who uses it, I'll have to give you some very specific pointers. Also, the WME requires some audio in the source file, I don't know why... but if the animation doesn't have any audio, you'll be better off with Quicktime.
Windows Media Encoder
If you wan't to chat for realtime help I'm, 111083857 on ICQ, and GrandAdmThrawn on MSN.
Post what you think should change next year for animations. Tyler Olds 3D Animation and Competition 21 20-04-2003 03:19
Use of your animations VanWEric 3D Animation and Competition 3 10-03-2003 21:02
animations... archiver 2000 1 23-06-2002 22:11
image upload max size Mike Soukup CD Forum Support 3 26-11-2001 11:29
animations Andrew Dahl 3D Animation and Competition 8 07-07-2001 04:41
