Go to Post And, if you don't know what something means, say so, we'll be happy to explain. - DonRotolo [more]
  #46   Spotlight this post!
Unread 07-01-2003, 23:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally posted by nwagers
since when do measurements start at one? all the rulers in my house begin with 0. the way the rules(update) read all the tubs are counted down, so unless you can stack enough tubs on their sides to add a complete SHU it does nothing to your multiplier
We just need to know for sure if the stick starts at 1 or zero.
  #47   Spotlight this post!
Unread 07-01-2003, 23:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally posted by sanddrag
1 SHU = 14 3/4 inches. 1 bin in standard position is 15 3/4 high. So according to the SHU stick starting with 1, a bin would be above the 2 mark already.
Will someone clarify all of this really simply please?
Imagine that the SHU measuring stick were the X-Axis of a graph. The question, really, is where is the zero of that graph. Is it at floor level, or is it one SHU below floor level.
By the previous descriptions of scoring, the zero was one SHU below floor level. FIRST has changed this so that it now rests at floor level.
<14.75" = 0 (i.e., no bin, broken bins, etc.)
14.75"-29.50" = 1 (a single bin, at 15.75", falls into this category)
etc.
This is clear when you consider why they lowered the SHU measurement to 14.75". See, if the floor were 1, it would be as you said, and a single bin would be 2 SHUs tall. But, since the floor is 0, that single bin is now 1 SHU tall. Furthermore, with an SHU of 15.75", and while rounding down, two nested bins would not be tall enough to break the 31.5" threshold and would round down to be a stack of 1.
The new SHU measurement, coupled with the change to rounding down makes a lot of sense. I get it now. I like it better this way. One bin should count as one bin, regardless of its orientation.
--Madison--
...down at the Ozdust!
  #48   Spotlight this post!
Unread 07-01-2003, 23:31
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
Don't qoute me on this
"Fractional stack heights are rounded down to the nearest SHU"
- Team Update #1 so non-dispudable
One SHU is one bin's height
using basic logic, (which FIRST has been known to ignore):
1 bin = 1 SHU, and since everything gets rounded down, a bin on its side, 1.5 bins = 1.5 SHUs, which turns into 1 SHU...
I am NOT sure of any of this, it is just my reading of the facts, and is open to dispute, especially as the team update also says SHUs are 14 3/4" high measurements, when bins are 15 3/4" high in the rule book.
<edit> according M. Krass above this post, the measurements make sense... i didn't do the math, but it sounds like he did, and i'm currently to tired to figure it out </edit>
Trust, Love, and Magic
  #49   Spotlight this post!
Unread 07-01-2003, 23:34
If I can take your word that the stick starts at 0, then a ruling has been made. 1 bin will count for 1 in any orientation (which really sucks because that's not the way Woody presented it at kickoff) Can you confirm for certain that the stick starts at 0? Also, your stack will count for how many bins are in it unless you are able to stack enough on their side that it raises the stack a height of one whole bin. (highly unlikely)
Just so no one has a heart attack, the real SHU is 14.75. Krass was saying IF right there.
  #50   Spotlight this post!
Unread 07-01-2003, 23:36
make me care
#0555
Team Role: Student
WHAT?? two bins count as one? what the hell is going on,
oh, my arm, it hurts, i think i'm having a heart att----v/\v----v/\v---- ---- ----
  #51   Spotlight this post!
Unread 07-01-2003, 23:38
Re: Don't qoute me on this
No it doesn't. One SHU = one nested bin height. So one bin on the ground in standard position would break the 14.75 barrier, and be rounded down to 1.
  #52   Spotlight this post!
Unread 07-01-2003, 23:41
skittle5's Avatar
skittle5 skittle5 is offline
#0116 (Epsilon Delta)
Team Role: Animator
skittle5 is an unknown quantity at this point
Send a message via AIM to skittle5
clearing up the pyramid
the way you get the scor of boxes is, count the number of boxes in your scoring area even if they are in the stack, subtract the height of the stack from the total number of bins on your side, in this case since you say that it will be a stack counting as four and there are seven boxes in your scoring area, all of these boxes are in the pyramid, so you subtract four from seven and that gives you three, and since you have a hieght of four you times three by four and the score of the pyramid is 12, trust me dave lavery is on my team
  #53   Spotlight this post!
Unread 07-01-2003, 23:48
At this point I'd like to remind everyone to read an entire thread before posting false assumptions such as this.
  #54   Spotlight this post!
Unread 08-01-2003, 00:00
skittle5's Avatar
Team Role: Animator
1 bin counting as two
i would just like to say that if a bin is on its side then it counts as a stack of two if you have 2 bins and one on its side this will count as no points because you have a bin that counts as two and a total of two bins 2-2=0, 2*0=0 so it counts as none
  #55   Spotlight this post!
Unread 08-01-2003, 00:04
Re: 1 bin counting as two
No, no no no no no no. READ BEFORE YOU POST!
  #56   Spotlight this post!
Unread 08-01-2003, 00:09
skittle5's Avatar
Team Role: Animator
one bin as two
david lavery is on my team and he says that if a bin is on it's side then it counts as two
  #57   Spotlight this post!
Unread 08-01-2003, 00:11
Re: one bin as two
dave?
  #58   Spotlight this post!
Unread 08-01-2003, 00:13
skittle5's Avatar
Team Role: Animator
Re: Re: one bin as two
dave?
David (dave) Lavery you know one of the peoplewho made the game, that one
  #59   Spotlight this post!
Unread 08-01-2003, 00:15
When I said dave? I meant does he have anything to say about this. I know who he is. And now I will abide by this
You also agree not to ..... use the forums as a real-time chat, continuing a 2-3 person conversation on for numerious posts in a short period of time.
and end this discussion.
  #60   Spotlight this post!
Unread 08-01-2003, 00:17
skittle5's Avatar
Team Role: Animator
agreed
Tossing a bin at the ramp in HP Cory Rules/Strategy 12 04-06-2003 12:13
Illegal human player bin placement Mike Soukup General Forum 29 01-04-2003 21:17
Where to find a bin? Krystal314 3D Animation and Competition 3 18-01-2003 12:56
Bin Stacks Brad Swindell Rules/Strategy 7 05-01-2003 19:47
Additional Hardware list confusion archiver 2001 4 23-06-2002 22:29
