Go to Post Just think outside the box but inside the 28" X 38" X 60" rectangular prism and you may come up with a solution. - Pavan Dave [more]
Unread 08-01-2003, 14:09
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
new bosch pinion and mounting
Does anyone have an idea about mounting the Bosch motor this year. Are the small pin insets on the sides capable of taking a tap? Notice the face is no longer tapped for mounting? Just looking for other ideas beside clamping the motor's body.
Anthony
Team 221 --> 857
Unread 08-01-2003, 17:16
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
The lowest risk way of mounting the drill motors is clamping around the sleeve. I rly, RLY wouldn't tap any hole in a motor casing, even if it does look like it could take a tap.
btw- are you speaking of the bosch drills or the vendor>?
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
