Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 09-01-2003, 17:13
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Re: type of material; conveyor belt
Originally posted by Alyssia
1. Is it legal to use stainless steel in building the robot?
2. Is there a "common" conveyor belt that most teams use?
3. What is the maximum pneumatic RAM?
Thank you.
1.Yes it is, as long as you have no sharp edges, or any of the touching the ground
2. Use for what? Wheels, Transmissions, Arm belts
3. I belive that you can only use 120psi before the saftey valve activates reliving pressure, not 100% sure on that one
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
material and fastener usage archiver 2000 1 24-06-2002 00:08
Illegal material PDonovan Rules/Strategy 13 16-05-2002 16:53
WASH scouting fields Mike Soukup Scouting 0 04-02-2002 02:39
Best material for wheels. Dr.Bot Technical Discussion 0 21-01-2002 23:32
