Go to Post Originality in Sponsorship can get you a lot of places. - MysterE [more]
Unread 10-01-2003, 12:55
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
Re: Clarification of question 2
Originally posted by cybermind
A clarification on the "common" conveyer belt question: (#2)
We are thinking of using conveyer belting for driving (Like a tank). But since we are a rookie team we are not sure where to get the supplies or even what we need. Specifically what we wanted to know is:
What conveyer belt do you recomend?
What wheel are we supposed to use with the conveyer belt?
How did you attach the conveyer belt to the wheel?
Thank you for your help!
OK, so you want a tread design. First off, if you have the money I like BrecoFlex....you should have received a catalog from them in your kit. They sell the material and the pullies for it. Otherwise you could make your own tank treads like we did two years ago (look in the bottom right of the picture with me and pink hair). You can also go with something like double sided rubber belting from Gates.
As for the wheels, in previous years teams have used conveyor belt material and attatched them to wheels...like these or these . We got material(we used neopreme) from McMasterCarr and attached it with screws (you could also use rivets). This year this is a little more tricky because FIRST will be stingy about metal on the playingfield...glue seems one of the only options in this respect....
~Adam
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
material and fastener usage archiver 2000 1 24-06-2002 00:08
Illegal material PDonovan Rules/Strategy 13 16-05-2002 16:53
WASH scouting fields Mike Soukup Scouting 0 04-02-2002 02:39
Best material for wheels. Dr.Bot Technical Discussion 0 21-01-2002 23:32
