Go to Post It's more of a "gracious professionalism" thing. - Matt Leese [more]
Unread 11-01-2003, 12:31
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Connecting motor to treads
Originally posted by Carl Owenby
Our team wants to use tank type treads this year. Can the motor be connected directly to the timing belt drive pulley? If not, what's the best method to transfer power from the motor to the drive pulley? Chain and sprocket? Gears?
In most cases, you will want more torque to propel your robot than the output shaft of a motor can provide. There are some motors, however, that can be used for direct drive.
I'd recommend using sprockets or spur gears to transmit power, as well as establish a favorable gear ratio. Each have their pros and cons.
In short, spur gears seem more reliable because they don't rely on chain. However, changing the ratio between them is more difficult, as you'd be faced with the challenge of finding a new, acceptable ratio and maintaining the same center-to-center distance.
Sprockets allow more flexibility where changing ratios is concerned as all that is required is to change the sprockets and adjust the chain length. Chain, however, has the potential to skip teeth or fall off altogether. A tensioning system is a must.
--Madison--
...down at the Ozdust!
Tank treads and specialty wheels archiver 2001 7 24-06-2002 01:25
TANK TREADS...welp. archiver 2001 13 23-06-2002 22:50
Which form of connecting a rod to a wheel is the best? SilverStar Technical Discussion 2 27-03-2002 20:30
What problems have you encountered using treads? M.I. Technical Discussion 8 15-01-2002 22:13
Wheels, treads... Dan 550 Rumor Mill 23 19-12-2001 15:38
