Good question Joe
I had the same quesiton ... we have these gears installed on the shafts using the stepped key stock, but one or two of them can still easily slide along the axis of the shaft - also without collars the entire shaft can slide within the bearing inner race. I don't believe FIRST provided collars for the 5/8" shaft (unless I missed them), but then how did the FIRST engineers build a "working" robot chassis at the kickoff using only parts in the kit?
Stu Bloom ![]() Mechanical Engineer - Rolls-Royce Corporation Pike High School RoboDevils - 1018 |
| Has any one stuck a drill motor in the FP trans? | Lotownvw | Motors | 15 | 21-04-2003 23:57 |
| drill motor mounts- again | Jeff Sharpe | Motors | 6 | 07-04-2003 23:20 |
| A new record for breaking a drill motor | ZacharyD | Technical Discussion | 23 | 16-01-2003 16:58 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drill Motor and FP Motor Shaft Diameters | Andy Baker | Motors | 4 | 11-06-2001 20:12 |
