Go to Post At the competitions you can look like an idiot and nobody cares, that makes me happy... - Laura 1547 [more]
Unread 12-01-2003, 14:43
Jeff Sharpe Jeff Sharpe is offline
#0473 (Montana State Robotics)
Jeff Sharpe is on a distinguished road
You've hit the root of my question. Why cut the power to the Chalupa? The drill and Chalupa would both operate in their strongest rpm window during low gear mode- no fighting. In high-gear the Chalupa would be spun at 2.4xs its free load rpm as the drill motor would be doing all the work (all we've changed is the drill assembly output speed by shifting its gear from low to high). The voltage would still be applied to the Chalupa so it's turning resistance should be less. Also back current shouldn't be able to over power the 12v applied? J#
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
Can I drill the output shafts of unmodifiable motors? archiver 2001 4 23-06-2002 23:08
