Go to Post For those of you who don't want to read a block of text: Respect the Tools. - Andrew Schreiber [more]
Unread 12-01-2003, 20:56
Re: Re: Pin 12 ground - NOT GOOD !
Originally posted by Dave Flowerday
This dongle (and the yellow dongle) isn't using pin 12 as ground. We're using pin 8 as a ground. Pin 12 is being pulled to ground by pin 8, and pin 5 and 6 are being pulled to ground by pin 8 when the appropriate side of the switch is closed. This is still how it's described in the 2003 OI Reference. Do you think that the 2003 OI Reference is also incorrect?
Since pin 12 and pin 15 were connected, originally, for channel access, I must have mixed them. The original 2000 Docs call for ground on 15 and 8 (the two end pins on the connector, but 15 is no longer to be used as ground.
I've had a match timer that disables controllers and allows channel selection since last year, and pin 8 is the sole ground used.
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
