Go to Post I remember...my first nationals in 1998, when I was in High School, and thinking "Wow, that's really cool. Engineering looks fun..." - Karthik [more]
  #34   Spotlight this post!
Unread 14-01-2003, 06:32
Matt Reiland's Avatar
'The' drive behind the drive
Originally posted by Jeff Waegelin
Question: has anyone welded Bosch extrusions? Is this necessary, or is bolting it sufficient?
Jeff, you should be able to get it locally from the Distributer Micco right over by 696 & Dequinder, I think you guys are working at the Tech Center this year right so it's pretty close.
We have welded it, it works. If the joint is critical we usually bolt through the extrusion instead of using the TNuts since as other people have noted the TNuts can break through the extrusion with enough force, however it will be pretty impressive if you break off a thru-bolted. I think the picture that was bent was a 20x20 on a tether that got pinned into the side of the field pretty hard.
Will Kidder - willkidder@kidderassoc.com
MICCO (Moddular Industrial Comp Co)
25831 Commerce Dr.
Madison Hgts, MI48071
PHONE: 248-584-4440
FAX: 248-584-1117
Structural Aluminum Framimg Carl Owenby Technical Discussion 2 12-01-2003 19:29
Difference in aluminum archiver 2001 1 23-06-2002 23:49
Legal fastener for aluminum structural framing question. archiver 2000 8 23-06-2002 22:44
Bosch Extrusion Tony G. Technical Discussion 4 11-01-2002 19:04
Bosch Extrusion Tony G. Technical Discussion 0 10-01-2002 10:26
