Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
Unread 15-01-2003, 19:58
crazycliffy crazycliffy is offline
crazycliffy is an unknown quantity at this point
thanks for the quick response.
I understand, it is a "switch" type sensor.
Since from the schematics from first says
connect black wire to Switch3 and white wire
to Switch4. This means 12 V goes to Switch3,
and then 0 Volts goes to Switch4 (On State). The 12V,
goes directly to the digital input..
Does this short circuit or cause problems to the
robot control (digital input)?
I read from the Innovation's RC Reference Guide, says...
"Digital Inputs are "looking" only for ground signals
to become "active".. Do not connect positive voltage
to any switch or digital input pin, only ground"
Thanks for your advice!!
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
Find any optical sensor in catalogs? GreenDice Programming 1 13-01-2003 18:05
OPTICAL SENSORS??????????????????? NM_programming Technical Discussion 2 13-01-2002 17:41
