Go to Post In other words, don't count your chickens before they hatch, even if the shell seems broken. - Lil' Lavery [more]
Unread 16-01-2003, 19:11
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
There's an even easier way to tesion chain. Take a piece of 1/2" dia delrin rod about 1.5" long or enough longer to bridge whatever gap your chain is runing through. Drill a hole through the center of the rod perpindicular to the axis of the rod about 3/8" from each end. The two holes should be parallel to each other. Slide the rod under the chain but up against some supporting structure until it is just a little too tight. Bolt the rod down. The chain will wear into the rod until it is the right tension. It will then stop wearing into the rod as a sort of equilibrium is reached.
It takes 10 or 15 minutes to fabricate and install.
Christopher H Husmann, PE
"Who is John Galt?"
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
direct Drill motor drive wrong or right rcubes85 General Forum 6 11-02-2003 18:11
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
