Go to Post I personally think a large trophy and that warm, fuzzy feeling you get inside is a satisfactory prize for winning a competition. - Dan Petrovic [more]
Unread 15-01-2003, 15:48
Jim Smith Jim Smith is offline
#0279 (Tech Fusion)
Jim Smith is an unknown quantity at this point
Nylon Roller Chain Sprockets
Does anyone have any expereince with using the nylon sprockets for the final drive to the wheels?
Unread 16-01-2003, 22:23
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
not sure
not quite sure why my physics teacher and team shrieked in horror when I showed them the page in msc with those. they behaved like a vampire exposed to sunlight, something about shattering and being fragile!
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 17-01-2003, 15:51
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
The big problem I see is getting the torque to the sprocket to start with... if its cross drilled.. the force is concentrated in one place.. but if you could somehow spread it out....
but i think the best would be to go with steel.
same for the chain
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 17-01-2003, 16:37
Jeremy Davis Jeremy Davis is offline
#0422 (Mech Techs)
Jeremy Davis is an unknown quantity at this point
Send a message via AIM to Jeremy Davis
Stay away from nylon...
My team tried nylon sprockets on the drive team two years ago, and we went through the originals and both spares we had bought in the weekend before shipping. Needless to say we lost a couple days of practice and had to replace our broken plastic sprockets with steel ones before our practice rounds at regionals. I would recommend sticking with steel.
Unread 17-01-2003, 16:42
The big guy
IF you absoultly had to have to use them.. id say get like 3/8" or bigger in WIDTH that may withstand the forces of a fast drivetrain, MABY.
Justin Stiltner
KI4URQ
Unread 19-01-2003, 04:36
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
when done right
during our final 4th place climb in '99 we were using nylon roller sprockets.......
with no problems......if mounted right, these fiberglass reinforced sprockets can save weight and be very effective.
Anthony
team 221-->857
Unread 20-01-2003, 20:01
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
I think they would be fine. Just use large ones, (like 30 tooth) and bolt the sprocket directly to the wheel placing your fasteners as far away from the shaft as possible. We plan to use them this year, I'll try to remeber to post if we have any problems.
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
1/4" chain and links from small parts archiver 2001 2 24-06-2002 00:18
Ball Rollers archiver 2001 8 23-06-2002 23:26
Roller Chain Adrian Wong Inventor 3 23-02-2002 17:21
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
