Go to Post Many people follow that advice, as if Ohio is Mordor or something. - Travis Hoffman [more]
Unread 17-01-2003, 22:08
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Question Does the line continue up the ramp?
Does the white line continue up the ramp?
The thread below makes mention of the supports in line with the tape being reflective. I just want a little more clarification.
http://www.chiefdelphi.com/forums/sh...tape+up +ramp
Unread 17-01-2003, 22:12
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
no, the line does not continue up the ramp.
~Adam
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
No
The line DOES NOT continue up the ramp.
edit- Adam beat me... /edit
Unread 17-01-2003, 22:46
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
The line itself does not continue, but I believe that one of the ramp supports lines up directly with the white line.
Jeff Waegelin
Unread 18-01-2003, 00:48
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
TWO of the ramp supports line up with the two lines. These supports are not painted white, but they are aluminum, and should be easily detected by your optical sensors.
One twist -- which I haven't had a chance to play around with -- is the fact that over this aluminum support is the wire mesh. This will PROBABLY cause the signal from the support to flicker as you go up the ramp.
Unread 18-01-2003, 18:07
Re: Does the line continue up the ramp?
The tape is not the reflective tape used for marking the containers for human player use. From "the Game" section 10.4 "If tape is used to mark the white tapelines that run from inside of the starting areas to the base of the ramps, it will be Shurtape, PC-628 Premium Grade Tape, Vinyl Coated Cloth, White, 2” wide. If you cannot find this tape, go to:
www.tapemonster.com.
If FIRST decides to use paint or some other means to indicate these paths, you will be informed in a
Team Update."
While it is true that the wire mesh is copper flashed, I would not depend on the copper remaining for an entire competition. I expect the mesh to become worn and polished.
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
Q&A Discuss: Does the line continue up the ramp? CD47-Bot Extra Discussion 5 18-01-2003 01:01
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
