Go to Post Minus the one time when our Autonomous mode actually reversed, ran into the robot behind us, and lodged them into the rear wall - MysterE [more]
View Poll Results: What will be the most effective bot type this year
Ball Dumper 6 4.96%
Ball Vacuum/Shooter/Pusher 27 22.31%
Bully Bot 13 10.74%
Goal Controller 75 61.98%
Voters: 121. You may not vote on this poll
Unread 06-01-2002, 00:47
l1jmx's Avatar
l1jmx l1jmx is offline
#0840 (ART)
l1jmx is an unknown quantity at this point
Send a message via AIM to l1jmx
Hybrids
I initially thought a goal controller would have the potential to be the most powerful since the scoring medium of the balls is completely dependent upon the location of the goals. If someone (and I'm sure they will) can figure out a way to grab all 3 goals - 520 lbs of robot and goal oughta be fun to manuever with - they've essentially guaranteed a win. Then again, the whole opponents score thing messes it all up since this would basically prevent them from getting any points. After much contemplation I've actually realized that a faster, more maneuverable robot able to drag only 1 goal with a ball-gatherer of sorts ought to be much more effective. A team with 2 bots of this sort could effectively dominate the match by reaching first and controlling 2 of the 3 goals, and filling them with balls. They would then, based on what the opponents did with the third goal, be able to shift the balls around to get as close as possible to an even distribution. I think inspite of everyone's loving a good lumbering, robot-crunching bully and all of the ensuing accidental carnage, bully bots are going to be the least effective just because of the danger of dq with risks of malicious intents and "entangling."
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 30-03-2003 23:00
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 12-01-2003 22:19
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 05-01-2003 22:04
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 21-01-2002 07:52
