Go to Post The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning... - s_forbes [more]
Unread 06-01-2002, 08:24
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Compressor usage
Just a general comment regarding the compressor.
This compressor is designed for "intermitment use", which basically means it's a low cost unit.
Whenever designing with an intemitment use device, one of your design criteria should be to run it as little as possible while getting the performance you need. This will minimize overheating, and prolong the life.
In the case of the compressor, this means minimizing the consumption of air. One simple way of doing this is to minimze the cylinder bore and stroke to only what you need. This design challenge will not only reduce the comsumption, but in the industrial arena, will save money.
As a side note, also in the industrial world, the cost of running a compressor can be quit high, so minimizing air consumption can save a lot of money over time.
Hope that info helps.
Regards,
Scott358
Festo Corp
Corporate Sponser of Hauppauge High
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
No antimatter allowed on robot Jan Olligs Chit-Chat 9 19-02-2002 21:13
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
