Go to Post Soon, some of those teams will learn to rise about current and former powerhouses. - Akash Rastogi [more]
Unread 05-01-2002, 22:59
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Pneumatics pump allowed on robot?
I'm again sorry if this is a dumb question, but I have not gotten to the KIT PARTS PDF of the manual, and itr might be answered there.....
But my question is: Is the electric air pump allowed on the robot? The rules sort of state that all Pneumatics power must come from the storage tanks pumped up only by the supplied air pump...but that doesn't mean it can be mounted on the robot. (I'm an electrical guy, but those tanks sure look SMALL....so I am guessing that the pump can be on the robot. )(And I thought I saw that a relay module may power no more that one motor or pump)
-Quentin
Team 4987: Megarams
Unread 05-01-2002, 23:09
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
yep it can
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 05-01-2002, 23:16
asher asher is offline
None #0031
asher will become famous soon enough
yes it can, and be careful, it will burn you, i promise, i can show you the scars
Unread 06-01-2002, 02:28
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Not only can it burn you.. but the seals inside will suffer from this heat as well. We experanced that last year and our compressor that overheated on us (was workin on the programming and the engineers decide to "just let it run.. itll be ok") after over heating it took forever and a day to get to 120psi....
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 06-01-2002, 08:24
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Compressor usage
Just a general comment regarding the compressor.
This compressor is designed for "intermitment use", which basically means it's a low cost unit.
Whenever designing with an intemitment use device, one of your design criteria should be to run it as little as possible while getting the performance you need. This will minimize overheating, and prolong the life.
In the case of the compressor, this means minimizing the consumption of air. One simple way of doing this is to minimze the cylinder bore and stroke to only what you need. This design challenge will not only reduce the comsumption, but in the industrial arena, will save money.
As a side note, also in the industrial world, the cost of running a compressor can be quit high, so minimizing air consumption can save a lot of money over time.
Hope that info helps.
Regards,
Scott358
Festo Corp
Corporate Sponser of Hauppauge High
Unread 06-01-2002, 12:30
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Just let it run?
How did you get an always-on pump past the inspectors? When we were getting checked, that was the first thing they pointed out that we had to fix.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
No antimatter allowed on robot Jan Olligs Chit-Chat 9 19-02-2002 21:13
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
