Go to Post Sometimes our greatest failures lay the foundations for our greatest success. - =Martin=Taylor= [more]
Unread 21-01-2003, 18:45
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
Question sprockets
I just wanted to get peoples opinions, which do you think is better, Aluminum, Steel, or Plastic sprockets?? My team is having a minor problem in agreeing ....Some want to use Steel (which I believe is over kill and if you are tight on weight its not a good idea.) and then some want to go with AL and or Plastic.
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 21-01-2003, 18:51
hi_im_sean hi_im_sean is offline
hi_im_sean is an unknown quantity at this point
assuming you are talking about drive gears
i dont think steel is much of a problem as long as its not to big, aluminum would be the best , but i would never use plastic. it will break or strip out way to easily.if your budget allows it i would use the aluminum gears , evn though they are more expensive.
Unread 21-01-2003, 18:57
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
I would just cut out the idea of aluminum or steel sprockets. Because drive gears/sprockets are under constant force and stree during the match, you want to use steel or cast iron. It's heavy, I agree, but it is the best choice. Our team gets sprockets/chains/gears machined by Borg Warner people and realize they make 90% of the world's small car chains and 80% of the larger automobile chains... such schweet quality.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 21-01-2003, 19:04
Pengiun Joe Pengiun Joe is offline
Pengiun Joe is an unknown quantity at this point
Steel is best. If you're willing to buy extras and replace them periodically, aluminum may be worth it if weight is that important. Never plastic. Never.
Joe Whateverski
Freelance FIRST
Unread 22-01-2003, 23:30
Unread 23-01-2003, 22:21
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
Definately Steel.
Weight however is an issue, which is why you pump it full of holes. You can even lathe down the hub in many cases (since often it is not needed, or at least doesn't have to be as big as it is). Generally, we manage to cut at least half the weight off our steel sprockets (and some of the gears too).
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 24-01-2003, 00:18
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
the teachers, engineers, and some knowledgable students on my team (myself hopefully included) all shudder and spasm at the idea of plastics sprockets when we saw them in the big blue book. its scary, those things - in a 130 lb robot - that will be ramming into things at top speeds? AAHHHHHHHHAHHHHHHHHHHHHHHAHHHHHHHHHHHH ahh ah
Trust, Love, and Magic
Unread 24-01-2003, 00:22
Umm Errr...
lol. *pictures total annihialation as little bits of plastic shrapnel come flying out of a robot*
okay mabie thats a little overdramatic bot SAY NO TO PLASTIC
1139 Alumni
Unread 24-01-2003, 00:39
Dick Linn's Avatar
no team (Synergy)
Aluminum is fine, and is a lot lighter. Racing go-carts and motorcycles use aluminum sprockets, and they have a lot more horsepower! Anyone know of a source for aluminum sprockets with a 5/8" bore?
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 24-01-2003, 09:59
AKA: Adriana
Try Small Parts or Mcmaster Carr.. I would say look into Mcmaster Carr first.
Unread 25-01-2003, 19:11
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
If you mount, and use them properly, plastic will work just fine, at least for wheel driven robots. The important thing is how you transmit the load from the shafts to the sprockets. If you get the chance, stop by our pits and check out our plastic sprockets.
Unread 25-01-2003, 19:36
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Cast iron? That is a little brittle and extremely heavy if I remember correctly. I think you may be refering to gears made of pressed powdered metal like the old chiaphua gear cluster. If you want a good idea of how hard that thing was, try to grind it off. The lathe wouldn't even scratch it.
Unread 25-01-2003, 22:42
Rick Gibbs Rick Gibbs is offline
#0145 (T-Rx)
Rick Gibbs is an unknown quantity at this point
Aluminum is just fine
We've used aluminum sprockets for the last couple years (manufactured on our shop's CNC). We've had no problems and saved (literally) pounds of weight vs. steel.
Unread 25-01-2003, 22:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Just don't have 5 subsystems and the weight should be fine. We use standard issue (formed powedered metal?) black steel sprockets from SPI or McMaster.
SPI is way overpriced though.
Unread 26-01-2003, 23:15
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
plastic is good enough for me...
I don't want to change anyone's mind but I can tell you that I am using a LOT of plastic sprockets this year.
Plastic is not as strong as aluminum and steel, but in the right application with the right design, it can be better than metal.
Your mileage may vary...
Joe J.
need help fast!!! Hubless 1/4 pitch sprockets Travis Covington General Forum 6 03-02-2003 18:44
modifying sprockets gail OCCRA 3 05-10-2002 12:13
Chief Delphi sprockets archiver 2001 23 24-06-2002 01:46
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
