Go to Post "I'm not teaching you math, I'm teaching you how to think. Hopefully that'll be useful to you someday..." - Karthik [more]
Unread 21-01-2003, 18:56
Team update #6 posted
http://www2.usfirst.org/2003comp/tmup6.pdf
Pinning is not longer a DQ but a disablement and they clarified under which circumstances a robot that is disabled in autonomous mode will be re-enabled in human controlled mode.
Note that the link on the docs page is wrong (points to team update 5), but the link from http://www.usfirst.org/robotics/ works.
Unread 21-01-2003, 18:57
Umm Errr...
do not follow the link one the FIRST website this links to team update 5 the correct address is http://www2.usfirst.org/2003comp/tmup6.pdf
1139 Alumni
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
There's some new specs for the drills as well.
Unread 21-01-2003, 19:08
Umm Errr...
bot most important of all.... we can interface the serial port on the RC!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
1139 Alumni
Unread 21-01-2003, 19:44
PyroPhin's Avatar
PyroPhin PyroPhin is offline
None #0263
PyroPhin is on a distinguished road
just curious.. what does that enable us to do? still learning my advanced electronics.
~Pyro
Squee!
Team 263, Aftershock:
Alumni, guy who comes back and fixes Krass's mistakes
Unread 21-01-2003, 19:47
It would allow you to pass data to and from the Stamp more quickly/more easily than trying to do it via the digital inputs. There are some definate disadvantages, however, that need to be weighed carefully against the benefits.
Unread 22-01-2003, 10:14
Jeff McCune's Avatar
Jeff McCune Jeff McCune is offline
Alpha Geek
#0677 (The Wirestrippers)
Jeff McCune is on a distinguished road
Send a message via ICQ to Jeff McCune Send a message via AIM to Jeff McCune
Does anyone have any specs, or guesses as to how much overhead one would incur adding another SERIN / SEROUT command to the main loop?
26ms (standard execution time of one MainLoop: cycle I think) is bad enough... Stretch that much more and your robot response time might not be adequate. There are, of course ways around this, but I'm wondering if it would be better for our time to scrap the 16 pin parallel cable we made to go to the digital inputs in light of using a serial in command.
Does the fact that the Program Port has a true hardware serial port, rather than a software one help things?
Team 677 - The Wirestrippers - Columbus School for Girls and The Ohio State University
EMAIL: mccune@ling.ohio-state.edu
...And all you touch and all you see
Is all your life will ever be...
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
