Go to Post I need to start sleeping now to make up for build season - Kingofl337 [more]
Unread 22-01-2003, 15:47
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
Originally posted by Matt Reiland
The gear in my post above starts life at right about 2lbs (1.93) after the mod is 0.4lbs. We used 4 of these last year that is over 6 lbs. savings on just those 4 gears alone, we did not have 6 lbs of bearings on the whole bot. Try saving 6 lbs of aluminum and you are talking many, many, many holes.
Yea, we actually did reatively the same thing to our sprockets last year and the weight difference was much different than aluminium.
--- We were also careful not to take off too much of the "blackened stuff" (or the hardened outer surface). This is because that surface gives the steel more stability, and without it the sprocket is more brittle. This is jus a lil thing, not too important when on the bot, but if you walking with it and u drop it..... well lets not go there
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Image Discuss: Team 60 - New Gear Box CD47-Bot Robot Showcase 2 09-02-2003 20:29
Gear Box Parts Posted on First Cad Library Ed Sparks Inventor 1 10-01-2003 01:54
Please help! Grease in the drill motor gear box? archiver 2000 2 23-06-2002 23:07
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
