Go to Post Friends don't let friends drive mecanum. Enough said... - Botsup [more]
Unread 23-01-2003, 08:08
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Ryan Meador will become famous soon enough
Tim, I'm glad there's at least one other person here that can comprehend what I'm saying. Thank you very much. I believe I've now ruled that out as a possibility But we've still got our external circuit (with rotary switch, of course). To make the rotary switch work, just connect it to ground like the rules state... I see no conflict or need for breakers, etc, as FotoPlasma suggested.
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
Unread 23-01-2003, 08:59
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Greg,
Not the E-Stop but the Robot Reset button on the Operator Interface.
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 23-01-2003, 09:03
ttedrow's Avatar
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Ryan,
You are 100% correct, Rotary switch, Toggle switch or Limit switch they are all 1's and 0's to PBasic.
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
Yes, Chute Door!!!
Unread 23-01-2003, 14:42
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Sorry. I didn't read carefully, and I got confused by Ryan's earlier reference to another thread concerning the e-stop button.
Unread 23-01-2003, 20:38
ejthe4th ejthe4th is offline
Active User
AKA: EJ Meyer
#0240 (Mach Vee)
ejthe4th is on a distinguished road
One of the problems I foresee is that for the digital inputs on the RC, we're warned not to apply any voltage to the switch pins, and to just ground them to return 1. "All additional electronics must draw power from a 20A circuit breaker," (The_Robot.pdf, page 13, emphasis added by me).
the rules say that you must have "All additional electronics must draw power from a 20A circuit breaker," but if you look above, the limit switch is essentially the same as a rotary switch except the rotary switch has more possibilities for outputs. i see this as many limit switches in one module. therefore, there would be no need to hook it up to a fuse.
Mach Vee Team 240
2004 GLR Semi-Finalist
Captian
Programmer
Electrician
Fabricator
Designer
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
variable? manodrum Programming 11 01-04-2003 17:20
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
