Go to Post That box you think you see is only an illusion. - Alan Anderson [more]
Unread 07-01-2002, 08:53
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Lightbulb
Someone noted that you can measure the voltage drop across a measure of wire. Yes, you would have to probably make that wire long to get a high enough resistance to measure.....but it is possible.
Now, why not just add a very small resistor in series....because it does not seem to be allowed. The rules say that the high impendence inputs of a circut may be attached to some number of points described, but it clearly indictates that this is OK because it does onto affect the circuit appreciatbly.
Placing a series resistor violates all the rules regarding how one MUST wire all the motors/spikes and other controllers......so it would be against the rules.
Still, the job is not as hard as it seems.....and with an op-amp or two (depeending on whether you need to build a true DIFFERENTIAL AMPLIFIER or if you can get a good common ground reference point).
There are of course other ways to do such a measurement using the magnetic radiation off the wire as current flows. I think this might be the better, more noise-free way to skin this cat.
-Quentin
Team 4987: Megarams
Custom Circuit Boards Billius Electrical 7 14-04-2003 12:48
message boards, chat rooms, etc archiver 2001 9 24-06-2002 03:55
circuit breaker archiver 2001 2 23-06-2002 23:18
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
Wiring custom toggle switches into operator interface DanL Electrical 9 13-02-2002 17:13
