Go to Post "What's said in the huddle, stays in the huddle..." - Mr. Lim [more]
Unread 27-01-2003, 00:26
Andy A. Andy A. is offline
Getting old
FRC #0095
According to IF, the fans are to be wired to the 12v input from the battery (not the output of the victor!). Make sure you get the correct polarity, as the fans may be damaged with reverse and won't acutally cool the FET's when reversed. The fans should run anytime the victor is powered.
Also, there is no keyed version of the PWM cable to fit into the shrouded Victors. Most cables fit in very snugg with a bit of force. If yours really don't fit, trim the black cable terminal, not the Victor!
Shroud or not, I recomend using just a touch of your favorite glue to keep the PWM firmly seated. I've had good luck with just normal elmers glue.
-Andy A.
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Speed controller fan replacement Rickertsen2 Electrical 11 16-01-2003 08:46
Speed Controller Limits yaman Technical Discussion 11 15-01-2003 18:40
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
