Go to Post "Rookie" just means you are new to the game, not that your team isn't as skilled as many already in the competition. - Bill Moore [more]
Unread 07-01-2002, 19:56
dense's Avatar
dense dense is offline
#0907 (Cybernetics Core)
dense will become famous soon enoughdense will become famous soon enough
Exclamation The weight of the goals a major factor!!
In this years game the weight of the goals are 130 lbs!!!
Your robot can be 130 lbs max.
That's a maximum 260 lbs of work.
The traction of the 130 lbs goals on the carpet will be a large problem in itself.
The key strategy may be in building a goal moving robot, which will require quite a bit of traction, and the wheels FIRST provides are no help at all.
-Shafi
Unread 07-01-2002, 19:58
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
goal weight
the goals actually wiegh 185 lbs.
Like Aquidneck Island Robotics on Facebook!
Unread 07-01-2002, 20:01
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
you positive on that weight? Last time i checked I think I saw 130. At kickoff I do remember hearing Woodie say 181 lbs.
Unread 07-01-2002, 20:05
Gadget470's Avatar
A Fire Outside
Just remembered...
Another side note...
Not really. Some teams may be grabbing 2 goals, putting the total to 390 lbs. Or, if you have a goal and an opponent has the other end thats much more work than 260lbs to overcome. Be sure to work that possibility in if you plan to latch on to a goal
Unread 07-01-2002, 20:09
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
Just think though... if you are able to lift two goals up off the ground, that gives you much greater friction force with the floor. No one's going to push you around if your motors are strong enough. F=uN so if u is constant and your normal force is more than trippled, no one's going to pick on you, that's for sure.
~Tom Fairchild~, who would never actually think of making a robot that does that.
Unread 07-01-2002, 20:10
dense's Avatar
Good Luck
We considered latching unto 2 goals...
But how do you suppose to move that amount of weight?
thx-(180 lbs goals even worse)
Unread 07-01-2002, 20:39
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Weight......
Here in Kokomo our goal weighs around 167 lbs...(am i right?), but i heard we have aluminium stripping around the edges of the wood and not steel...
so that should add some weight making it very similar to 180 lbs....
Purdue Alumni
Cummins, Inc.
Unread 07-01-2002, 20:40
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
Re: Weight......
yeah, thats what andy said when i was there
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 07-01-2002, 21:54
Elgin Clock's Avatar
FRC #0237 (Black Magic)
There is a way
There is at least one way for one robot to latch onto all three goals.
What??? Do you think I'm going to tell you how???? C'mon use that noggin of yours!!!!
Unread 08-01-2002, 22:26
Jay5780 Jay5780 is offline
no team (Aztechs)
Jay5780 will become famous soon enoughJay5780 will become famous soon enough
Goal Movement
I remember way back in 1999 the "Puck" being heavy especially with 3 bots on top. I don't know how heavy it was with or without the bots, but I know there were some teams that could move it. The one team the sticks in my mind the most was WPI's bot. There traction did help, but they had a very strong robot.
Just take the obvious into consideration. BUILD WHAT YOU NEED you are capable to do so.
Jay
Unread 08-01-2002, 23:31
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
If you check the update, as everybody should, it says that the goals weigh about 181 pounds a piece. Sounds like fun to me. Traction, now traction isn't the problem if you make your own wheels, which can easily be done with low expenses. Have fun!
Unread 09-01-2002, 13:53
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
when there was a puck on the field there were robots that could move the puck with two robots on it and another pulling the other way.
Look at team 61
It is all in the taction and motors. I would like to see a robot pull off atfter this is all done.
to push 3 goals and two robots at the same time. No Problem.
Power, Power that is what is going to win the game.
Mike
Look at the drive train of team 61.
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Stategy Debate: Goals Horizontal vs Goals Vertical archiver 2001 2 23-06-2002 23:32
WOW ! Mike Schroeder General Forum 12 12-03-2002 21:32
goals and balls Strath General Forum 0 14-02-2002 22:34
