Go to Post This is ChiefDelphi. There are threads on everything! - LauraN [more]
Unread 08-01-2002, 00:34
nick reynolds nick reynolds is offline
Senior Member
nick reynolds is on a distinguished road
Questions on rules
Can some one tell me the diference between GM18 and M6 they seem to contradict them selves.
Thanks
Nick237
Unread 08-01-2002, 01:02
Jon Abad's Avatar
Jon Abad Jon Abad is offline
Boston Regional Planning Committee
Team Role: Communications
Jon Abad will become famous soon enoughJon Abad will become famous soon enough
Send a message via AIM to Jon Abad
They feel complementary to me...
While M6 allows the use of the innermost face of the field barrier, it expressly disallows the top and rest of the border. GM18 futher explains... the safety aspect is the reason for them to be there and you should do your business without hurting them. If you touch the side of the barrier without damaging it, then you'll be fine.
GM18. The outer field barriers are safety features of the playing field and Robots should not be designed to react against them. Incidental contact with the barriers is acceptable. Pushing a
ball against a barrier to allow pickup of the ball or passage of the ball to the students is acceptable if the forces applied are not sufficient to damage the barrier or otherwise deform the playing field.
M6. Robots may be designed to operate by reacting against the carpeted surface of the playing field, the innermost face of the field border, the goals, balls, other robots, and the air. Robots
should not be designed to react off of the top of the field border or other parts of the field border. If your robot inadvertently drives on the top of the field border, you will not be
penalized unless the playing field is damaged.
Jon Abad
-Boston Regional Planning Committee
Dilemma - Letter of the rules v. spirit of the rules Natchez General Forum 27 03-04-2003 15:37
Time for new rules! archiver 2001 11 24-06-2002 02:01
rules questions... archiver 2001 5 23-06-2002 22:40
Technical Questions, Rules Brian_Lim Rules/Strategy 6 11-01-2002 14:09
Questions about rules ahecht Rules/Strategy 9 07-01-2002 22:45
